| Forum topic by MonteCristo | posted 328 days ago | 1336 views | 0 times favorited | 18 replies | ![]() |
328 days ago |
Topic tags/keywords: milling safety table saw In post http://lumberjocks.com/topics/2012, Bevel Ripping on a Table Saw With Right Tilting Blade, there is a reference to a YouTube video, http://www.youtube.com/watch?v=d7QXIN2X8-w&feature=user. The video is by a guy at “Workshop Essentials”. In his video he extolls the safety merits of a short rip fence. I think this guy is giving really bad advice in that video. I think he has not thought this through well enough. With his short rip fence the workpiece is under less control as the end of the cut is appoached because it has almost no contack with the (short) fence which is guiding it and of course no contact with the long rip fence. I would argue that this INCREASES the risk of kickback, not to mention that it will produce a poor quality of cut as the chance of the workpiece squeegeeng is much higher. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
18 replies so far
#1 posted 328 days ago |
Yes, I agree with him. |
#2 posted 328 days ago |
I think Steve is a very bright guy but I would prefer to just move the fence to the other side of the blade. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 328 days ago |
I prefer to move the saw, while the stock is secured, thank God for Festool and other plunge saws. Yeah buddy. Or, fence on the left side is my preferred method. |
#4 posted 328 days ago |
I like his method. If there is no fence at the back edge of the blade, there is nothing to pinch the wood. And since the wood is already been cut at that point, there is no real purpose for the fence extending beyond the back of the blade. It’s the front of the fence that keeps the work piece in a straight line. In fact, I see no purpose for the fence anywhere beyond the front cutting edge of the blade, other than to pinch the work piece. I’ve been pondering this since reading that thread last night, and I can clearly see the merits of that method. -- I'll grow up when ketchup bottle farts stop being funny. |
#5 posted 328 days ago |
Just to clarify, it’s not the right tilt bevel cut bit of the post that I am talking about, it’s the video that someone included in a reply that deals with a short stub fence (see the YouTube link I give). Some guys use a stub fence for crosscut work to make sure the offcut is not bound between the blade and the fence (main piece guided by a miter gauge) but this video advocates using a stub fence for ripping, something I think is a flawed idea. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#6 posted 328 days ago |
A retracted position fence is safer in ripping solid woods That’s why and when it is safer. In cutting sheet goods the retracted fence doesn’t I use an Austrian made saw. I had some Swiss/French |
#7 posted 328 days ago |
If you ask me I think that the Delta unifence took design inspiration from European saws. (Disclaimer I have one on my UniSaw) 1) The fence can me retracted so that you have a short fence I actually purchased a short fence for my unifence so that the long fence would not be in the way when I retract the fence such that it does not go past the blade. I agree with Loren above in all reality you do not need a long fence once the work piece is cut at the front of the blade the fence behind the blade is not needed. But I also do agree that when cutting sheet goods I do use the full fence. Oh and I did add a BORK to my saw which solves the no riving knife issue on the UniSaw. The past owner of my saw had removed the splitter so I did not even have that but I’ve been thinking of getting one a putting it back on along with the BORK. -- --- Richard Jackson |
#8 posted 328 days ago |
Loren: I understand your points but I remain unconvinced. It seems obvious to me that with the short fence the quality of cut will suffer. I would also argue that one has less control of the workpiece near the ned of the cut when using a short fence and that could lead to jamming the blade within the cut. I use a riving knife as I agree that stress in solid woods is always a possibility. With the riving knife, kickback should not be possible, but I acknowledge that if the stress expands the piece between the blade and the fence, in a severe case it will cause a jam. For my money, this is a risk worth taking, as I can easily kill the power before anything further ensues. It seems to me that even with a short fence, stress in the workpiece could lead to a jam in the case where the stress causes the workpiece to bear-hug the riving knife. Kelly Mehler wrote Taunton Press’s book on the table saw. He’s a super safety type of guy but if I remember correctly even he doesn’t advocate for a short fence when ripping. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#9 posted 328 days ago |
That’s why I love my Unifence, I can flip it to a short fence for narrow stock or retract it. The vid does make some sense to me although I’ve never tried it during ripping, maybe I will tomorrow and post back my thoughts. -- -- Rick M. |
#10 posted 328 days ago |
I tried some cuts with a scrap attached to my fence, that ended about 2/3 of the way to the back of the blade. What I discovered is that really short pieces, say 6”, can (and did) get caught and thrown back at me. Of course, I normally use other methods to cut pieces that small, such as the sled or by hand, but I was curious. For longer pieces it works like a charm. This is without tilting the blade. I have to make another insert for bevel cuts. Not sure but I might get to that today. -- I'll grow up when ketchup bottle farts stop being funny. |
#11 posted 328 days ago |
MC, I definitely see your point. I think it depends somewhat on the length of the board you are ripping. Making a lot of small boxes, I frequently rip some pretty short pieces, using my Grr-ripper and maintaining pressure against the fence. In that situation, you really need some fence out past the blade to keep the board on track all the way through the cut. However, in a situation where you are feeding the board from behind the blade the whole time, I would agree there is no need for the fence to extend past the blade. -- Charlie M. "Woodworking - patience = firewood" |
#12 posted 328 days ago |
My first instinct was that short boards would be more problematic but really what is the difference between short and long other than the amount of wood on the outboard side of the blade? Maybe the greater mass allows more control? Don’t know, still have to try it for myself. -- -- Rick M. |
#13 posted 327 days ago |
wormil: In the scenario I’m describing, I use my push block on top of the board, all through the cut. Without the long fence, there would be nothing to keep my hand from turning the board off course before the cut was completed. If you are just pushing the board from the rear, it doesn’t really matter. -- Charlie M. "Woodworking - patience = firewood" |
#14 posted 327 days ago |
I have a jig that I use to avoid trapping the offcut between the blade and the fence when bevelling with a right-tilt saw. The same jig would work if one is suspicious that stress in the wood is going to cause a jam. I got the idea from Fine WW or somewhere like that. I’ll post a pix sometime when I have time. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#15 posted 327 days ago |
I should check, but I think the long fence used in US is simply forbidden in Europe for safety reasons. The recommendations are: (translated from French and I am not a native English speaker) -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
