Adjustable Crosscut Sled
Forum topic by Bsmith posted 06-23-2012 05:02 AM 3944 views 0 times favorited 6 replies Add to Favorites Watch
View Bsmith's profile
Bsmith
330 posts in 2544 days
06-23-2012 05:02 AM
Anyone remember seeing a crosscut sled with an adjustable fence and base? I remember seeing one that you could adjust the spacing for a dado blade of different size cuts. The left side was stationary and the right side moved. Thanks in advance.
-- Bryan
13594 posts in 3215 days
#1 posted 06-23-2012 05:29 AM
here is the best i can do for you bryan
http://lumberjocks.com/search_results?cx=016283335483199634424%3A4na88symhay&cof=FORID%3A9&safe=high&q=table+saw+sled
sounds like a nice idea
if you find it
let us see yours too
View Loren's profile
9769 posts in 3522 days
#2 posted 06-23-2012 05:50 AM
Bsmith
#3 posted 06-24-2012 03:45 AM
Thanks Loren. I believe that is the one. I’ll see if I can find a video on it.
-- Bryan
View sras's profile
sras
4691 posts in 3003 days
#4 posted 06-24-2012 05:20 AM
Here is a version that I made. It adjusts for dado blades and blade tilt. Same construction method as the one mentioned above.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3586 days
#5 posted 06-24-2012 05:34 AM
I believe Woodsmith also had one.
Bsmith
#6 posted 06-25-2012 05:59 PM
Wow sras. Very well thought out sled. That will be copied a lot.
-- Bryan
