Delta 34-670 table saw loss of power
Forum topic by pweissmd posted 06-22-2012 01:36 AM 6212 views 0 times favorited 7 replies Add to Favorites Watch
View pweissmd's profile
pweissmd
2 posts in 2073 days
06-22-2012 01:36 AM
Topic tags/keywords: delta problem loss of power tablesaw
have a Delta 34-670 table saw I bought used 20 years ago. It has been fabulous – until today.
working on a project with a lot of 3/4” MDF. Saw was cutting it fine but after many cuts, the blade now stops (saw does not cut out!). Thought it was the blade – changed it to a new one – no difference.
This is a direct drive saw so it’s not a belt problem. Read in some of the other forums on Delta table saws that it could be I’ve worn the brushes out (good news) or that I am burning the motor out (bad news).
would appreciate any thoughts before I start taking it apart or looking for a new saw!!
Thanks!
-- Peter, Lake Anna, VA
7 replies so far
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
18198 posts in 3584 days
#1 posted 06-22-2012 01:53 AM
Check the brushes. May be stuck on the start winding. Rap it sharply with a mallet and / or move the blade and try to restart.
MrUnix
6372 posts in 2107 days
#2 posted 06-22-2012 02:36 AM
When it stops cutting, do you hear the motor still running or does it just hum? There is a belt on that machine, but it is internal to the motor so it appears as if it were a direct drive universal motor. To fix it, you would need to drop the motor and dismantle it a bit. That would be my first guess. Brushes and bearings could also be the culprit, but it sure sounds like a slipping/worn belt problem from your description.
Belt in question is part #226 below:
View knotscott's profile
knotscott
7877 posts in 3284 days
#3 posted 06-22-2012 03:05 AM
I think Brad’s on the right track. There is a small belt that could very well have broken.
TopamaxSurvivor
#4 posted 06-22-2012 04:08 AM
Direct drive isn’t so direct, eh? ;-))
View NormG's profile
NormG
5900 posts in 2912 days
#5 posted 06-22-2012 04:20 AM
I know someone who just had their belt break, it was $13.00 plus shipping from EBAY
-- Norman - I never never make a mistake, I just change the design.
pweissmd
#6 posted 06-22-2012 01:00 PM
Wow! I’m impressed with the fast response. I think I’ll enjoy this group!!
MrUnix: a belt in the motor housing??! What a surprise – but may be a good one. I see part #226 above.
Yes – the blade stops spinning, I don’t hear any significant hum. Based on my limited experience, it seems like a slipping belt.
Building a couple of night stands using 3/4” MDF – pretty dense stuff and the “slipping” just got worse as I kept cutting.
Okay smart guys – how do I get to the motor?
Thanks again to all! Really appreciate the helpl!
View Knothead62's profile
Knothead62
2581 posts in 2869 days
#7 posted 06-22-2012 01:04 PM
MrUnix, I find your expertise to be amazing. It is also amazing to see the knowledge and experience on the LJ forum!
