New JessEM mortise Jig
Forum topic by Everett1 posted 06-20-2012 04:06 PM 3861 views 0 times favorited 19 replies Add to Favorites Watch
View Everett1's profile
Everett1
213 posts in 2557 days
06-20-2012 04:06 PM
Whats everyone think of this new jig?:
http://www.jessemdirect.com/Pocket_Mortise_Mill_p/08200.htm
It’s 69 bucks! I might just buy one for the hell of it since it’s so inexpensive
-- Ev in Framingham, MA
19 replies so far
View jusfine's profile
jusfine
2422 posts in 2948 days
#1 posted 06-20-2012 04:37 PM
Looks like an interesting option to me! I have had Jessem products in my shop for many years, well built, great customer service.
I agree about the price. I have a mortise machine, but it’s so inexpensive and if it solves a problem or works once or twice on the jobsite or away from the shop, definitely worth the money!
Thanks for the link!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Ted's profile
Ted
2873 posts in 2234 days
#2 posted 06-20-2012 05:45 PM
Wow, that’s going to take a big chunk of the market from Festool’s Domino mortiser. If I wasn’t on such a tight budget I’d buy one right now.
-- You can collect dust or you can make dust. I choose to make it.
16275 posts in 4241 days
#3 posted 06-20-2012 05:49 PM
I was looking at it pretty hard. The only thing keeping me from buying one is that I already have doweling jig, and I don’t see any major advantage to these small loose tenons over dowels.
View GrandpaLen's profile
GrandpaLen
1650 posts in 2295 days
#4 posted 06-20-2012 05:51 PM
Everett,
I received an e-mail with an enbedded video on this new tool from JessEm 2 days ago.
Looks like a Quality alternative spin off, of the Festool ‘Domino’ loose tenon system at a reasonable price. I believe that’s what JessEm has in mind.
For what it’s worth, I had always thought that the Domino System could have been a lot more reasonably priced if it weren’t motorized, albeit a production oriented tool.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View Don Niermann  's profile
Don Niermann
219 posts in 3995 days
#5 posted 06-20-2012 05:53 PM
Got one and have made a couple if test runs. Looks good. Have not tried different setups yet
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
View Bill White's profile
Bill White
4948 posts in 3983 days
#6 posted 06-20-2012 06:29 PM
Now that’s a good piece of machinery.
Bill
-- bill@magraphics.us
View PurpLev's profile
PurpLev
8536 posts in 3671 days
#7 posted 06-20-2012 06:37 PM
I have their older models (large and small) – I think it’s a good setup IF you only have a handheld drill, and no other tools in your disposal. however, a drill is not really meant to be used as a mortiser (where force is applied sideways and not vertical) as do drill bits. a better solution is to setup a mortising jig with a router for speed, or use chisels. if you don’t have a router or chisels, but do have a drill and have a project or 2 that require mortising – this would be a good option.
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2795 days
#8 posted 06-20-2012 06:38 PM
Looks like another attempt at their mortise mill that flopped and went on clearance everywhere due to a high return rate.
This one might work out better I don’t know.
Here is the link to the reviews from amazon even though it’s no longer available
http://www.amazon.com/JessEm-Slot-Mortise-Mill-System/product-reviews/B00393OZI8/ref=sr_1_1_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
View sarahss's profile
sarahss
258 posts in 2672 days
#9 posted 06-21-2012 01:23 PM
@PurpleLev—I had the same concern as you about the drill not being designed to use as a mortiser. Do you think it might be possible to somehow use this jig with a plunge router, or would some other jig be better?
General now has the “ez-pro” that is also an alternative, but it doesn’t look like a real good option to me—just looks a bit cheap. What do others think?
I’m trying to find a good alternative to the Domino—just can’t justify the spend on one for my hobbyist needs.
Jeremy Greiner
#10 posted 06-21-2012 01:52 PM
@sarahss
For loose tenon joinery with a plunge router you can look at the mortise pal http://www.mortisepal.com/
View Gene Howe's profile
Gene Howe
10521 posts in 3451 days
#11 posted 06-21-2012 02:15 PM
Thanks Everett.
Just ordered one.
PurpLev
#12 posted 06-21-2012 02:36 PM
sarahss the bearings are set to match a drill bit. The jig could possibly be altered to fit a router but will require a larger top to support the router. It is really built for a drill for specific people in mind. I still hold onto mine thinoing of converting it for router use but am finding myself doing m&t with chisels anyway… Maybe some day ill post about it
Probably easier and cheaper to just build a router mortising fixture
sarahss
#13 posted 06-21-2012 02:42 PM
Thanks Jermey & purplev
View Brohymn62's profile
Brohymn62
125 posts in 2278 days
#14 posted 06-21-2012 02:46 PM
Nice tool
-- Chris G. ; Los Angeles, CA
View crashn's profile
crashn
528 posts in 2488 days
#15 posted 06-21-2012 04:54 PM
sarahss,
the General one is not worth it, I have one and tend not to use it. Kinda flimsy and getting things to lineup can be a pain. Should have returned it when i could, but left out of town for work and the timeframe to return passed. Oh well, maybe craigslist for cheap.
-- Crashn - the only thing I make more of than sawdust is mistakes
