Jointech CL-12
Forum topic by twowheel posted 339 days ago 807 views 0 times favorited 5 replies Add to Favorites Watch
View twowheel's profile
twowheel
5 posts in 858 days
339 days ago
Hi everyone, not real good with internet blog or forum sites, but I’ll take a run at it.
I recently purchased a one of a kind router table from a woodworkers estate. His son was selling the equipment from the shop and I could see from the craftsmanship in the router table the his dad knew what he was doing. Anyway, the table included a Jointech CL-12 router fence system. There are more than a few pieces to the fence system, but unfortunately, there are no instructions.
I tried unsuccessfully to access the Jointech website (not quite sure why I can’t connect).
If anyone can throw me a lifeline on this it would be much appreciated. I can probably get reasonably good usage of the fence without the instructions given the time, but I’d much rather be making some sawdust.
Thanks all
Rog
-- Rog; part time woodworker, part time biker, full time family man and living life
5 replies so far
View rustynails's profile
rustynails
355 posts in 701 days
#1 posted 339 days ago
You can’t get in contact with Jointech as they are no longer in business even though they still have a web site up. The fences work nice I used to have one on my old router table if you have any special questions feel free to ask and I will try to answer your questions.
twowheel
5 posts in 858 days
#2 posted 339 days ago
Thanks Richard, I haven’t had a chance to put the table to use yet. I’m going to keep your name in mind when I do use it in the future. I was able to purchase a 10 year old Laguna 18” bandsaw from the same shop. Have to run the wiring for the saw and find a good location for both in the shop.
rustynails
#3 posted 338 days ago
That’s kind weird as I used to have the same band saw as well? It’s a good band saw as well. I sold mine and purchased a brand new LT 18’’ with a Driftmaster fence and the ceramic guides. This is something I would recommend for the saw if doing a lot of resawing (Driftmaster fence). Did you see the saw work? Just asking because when I bought mine used the guy didn’t even know how to turn it on due to the 3 switch start up. Just let me know if you have any questions.
Richard
View Loren's profile
4901 posts in 1820 days
#4 posted 338 days ago
twowheel
5 posts in 858 days
#5 posted 338 days ago
The bandsaw I purchased has a 2 switch start up. I must pull the top switch out then rotate the bottom switch to the right. The Luguna I purchased has a 13” resaw capability which will be plenty for my purposes. I believe it has the cool blocks on it as well. I ran my new wiring to it, (runs 30 amp @ 240 volt). Using the 1.25 resaw blade that came with the saw I ripped a piece of oak. It was almost as smooth as as the table saw cuts, and it was a very accurate cut. A big upgrade from my 1/2 HP 14” Rockwell (which I still have a soft spot for).
The blade or the guides must be off a tad though, the saw makes a brief rubbing noise once a rotation. With time, I’ll get to the bottom of it.
I know the knew Luguna’s have matched resaw with wheel size and the must have multiple manufacturing locations now. This saw appears to have been manufactured by ACM for Luguna.
I know it is early, but I believe this is the last bandsaw I will buy (which is more than can be said for some of my other tools)
Thanks again
