trying to mimic this finish?
Forum topic by David Drummond posted 06-19-2012 12:57 AM 5383 views 0 times favorited 6 replies Add to Favorites Watch
View David Drummond's profile
David Drummond
97 posts in 2866 days
06-19-2012 12:57 AM
Anyone have any input on how to mimic this finish on eastern pine? It says it is reclaimed wood with a wax pine finish. I bought some 1”x 10”x 6’ pine boards from HD and experimented with a Bri-Wax rustic pine finish but it is too dark. I also had some Johnsons Paste wax and applied it but it looks like nothing was applied once it dries. The picture below looks like it has a darker tint than freshly cut pine and the reclaimed look is what I am aiming for. Any input would be appreciated!
http://www.potterybarn.com/products/mason-reclaimed-wood-headboard/?pkey=e%7Cmason%7C20%7Cbest%7C0%7C1%7C24%7C%7C8&cm_src=PRODUCTSEARCH||NoFacet-_-NoFacet-_-NoMerchRules-_-
Thanks!
David Drummond
-- "Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do... Explore, Dream, Discover” Mark Twain
View Loren's profile
10477 posts in 3849 days
#1 posted 06-19-2012 01:07 AM
Looks like it might be wire brushed and exposed to light.
View cabmaker's profile
cabmaker
1740 posts in 3010 days
#2 posted 06-19-2012 01:10 AM
Paint with latex (flat or satin). Paint with the same application skills a 3-4 yr old might employ.(dont want 100% coverage). Preferably by brush. Than sand to desired patina. Best if you sand shortly after paint flashes. Once dry apply topcoat of your choice. Enjoy JB
David Drummond
#3 posted 06-19-2012 01:24 AM
Cabmaker; not sure I understand your method of painting with Latex. I was thinking sun exposure might have some affect on the color of wood as well. Maybe I’m missing something??? Thanks for the input!
cabmaker
#4 posted 06-19-2012 01:31 AM
David I guess I missed your main objective. I assumed your aim was to achieve the wash finish. If yur after the aged wood look (for go the white wash, pickling) , doug fir might get you where you want to go with it. If your trying to achieve the whole deal imediately, youll probably need to apply (sparingly) a dash of oil stain to the equation to achieve the darkness I think your after. Once dry then do the pickling.
View bobsmyuncle's profile
bobsmyuncle
110 posts in 2892 days
#5 posted 06-19-2012 01:39 AM
Go out and get some pallets, preferably ones that have been sitting around for a while. Seriously, I was in an $800K house with a dining table made from “recycled pallet wood,” nailholes and all. She was so proud of it. I’m thinking it’s going to have some great patina after a spilled cheeseburger and red Kool Aid.
I am not sure. My guess is that it has some sort of chemical treatment that ages the wood. Acid or alkali with or without heat.
View SteviePete's profile
SteviePete
226 posts in 3504 days
#6 posted 06-19-2012 01:49 AM
Two part chemical cleaning—strong base, then acid. Sunshine dry, pickled white diluted latex. Distress, wirebrush, cut oil stain with LOPS, Dry it a few days. A sealer—shellac or thinned varnish. It is really tough to match in a short time—either do it all at once or roll the dice—you may not want a match. Good Luck Steve
-- Steve, 'Sconie Great White North
