How to repair gouged MDF?
Forum topic by JohnEinNJ posted 06-18-2012 11:17 PM 12809 views 0 times favorited 17 replies Add to Favorites Watch
View JohnEinNJ's profile
JohnEinNJ
94 posts in 2221 days
06-18-2012 11:17 PM
So I just finished building Wood Magazine’s tilt-top workbench (like this: http://lumberjocks.com/projects/57008), and was trimming up the maple band around the edge with a router. The router grabbed onto the edge, and did a little dance on the MDF top, making about a 1/2 inch deep by 3 inch long gouge :(. What’s the best way to fill & repair MDF?
17 replies so far
View tyskkvinna's profile
tyskkvinna
1310 posts in 2859 days
#1 posted 06-18-2012 11:20 PM
I have had decent luck with MDF sawdust and glue (since, yknow, that’s basically what it is right now!)
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Tyrone D's profile
Tyrone D
314 posts in 2206 days
#2 posted 06-18-2012 11:20 PM
When filling holes in MDF drywall compound works very good but I doubt it’d work in your situation.
-- --Tyrone - BC, Canada "Nothing is ever perfect, we just run out of time."
View Alexandre's profile
Alexandre
1417 posts in 2064 days
#3 posted 06-18-2012 11:22 PM
I think some sanding dust mixed with glue to make a nice thick mixture and pour it in, then when dry, sand it (Gosh, Wear a dust mask while doing this) and there you go! Hope this helps
-- My terrible signature...
View mark4345's profile
mark4345
71 posts in 2296 days
#4 posted 06-18-2012 11:26 PM
bondo
View Wdwerker's profile
Wdwerker
333 posts in 2107 days
#5 posted 06-18-2012 11:28 PM
Bondo rules! Drywall compound would only be for vertical surfaces.
-- Fine Custom Woodwork since 1978
View canadianchips's profile
canadianchips
2600 posts in 2870 days
#6 posted 06-18-2012 11:37 PM
Liz said it best. Sawdust and glue.
View doughan's profile
doughan
96 posts in 2464 days
#7 posted 06-18-2012 11:44 PM
saw dust and glue or bondo….bondo if you are in a hurry…..mix it hot and fast then use a putty knife to get it close before it gets to hard.
View AandCstyle's profile
AandCstyle
2950 posts in 2130 days
#8 posted 06-19-2012 12:20 AM
+1 Bondo
-- Art
View waho6o9's profile (online now)
waho6o9
8070 posts in 2450 days
#9 posted 06-19-2012 12:31 AM
bondo, yeah buddy
View mtenterprises's profile
mtenterprises
933 posts in 2566 days
#10 posted 06-19-2012 01:10 AM
Router out the damaged area and insert a new MDF patch, glue as needed.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
JohnEinNJ
#11 posted 06-26-2012 02:30 PM
Thanks to everyone for your responses. Just to wrap this up, I believe mtenterprises’ response (rout out damaged area & patch) is the “right” way to do it. But since a router mishap – due to my inexperience – is what caused the problem in the first place, I decided to do it one of the “less right” ways: glue mixed with sawdust. It took two days to dry enough to be sandable. Not pretty, but it worked.
mtenterprises
#12 posted 06-26-2012 08:57 PM
The only way you are going to learn is try and do. Now you will continue to look at your repair and say to yourself “I should have done it right” and one of these days you will make that repair correct.
MIKE
View DS's profile
DS
2855 posts in 2294 days
#13 posted 06-26-2012 09:06 PM
MDF + Bondo = MFEO
View DaddyZ's profile
DaddyZ
2475 posts in 2914 days
#14 posted 06-26-2012 09:26 PM
I would have filled with epoxy
View madts's profile (online now)
madts
1830 posts in 2213 days
#15 posted 06-26-2012 09:29 PM
Durham’s rock hard water putty. This stuff is awesome.
-- Thor and Odin are still the greatest of Gods.
