Reducing the diameter of wood dowl
Forum topic by BBOSIDE posted 06-18-2012 06:11 PM 4795 views 0 times favorited 10 replies Add to Favorites Watch
View BBOSIDE's profile
BBOSIDE
7 posts in 2305 days
06-18-2012 06:11 PM
Topic tags/keywords: ash turning shaping joining question
I currently building chairs and I’m using 1” wood dowels as components in the chairs.
The starting diameter of the Ash dowels are 1”.
I need to reduce the ends of each 1” dowel down to 15/16”.
The reduction lengths on the dowel needs to be 1” long.
As it will be joining a 4/4” piece of stock.
I do not own a lathe and have been sanding the ends with a sander.
To reduce the diameter as you can image this time consuming and difficult.
I also have no way to get constant results. So it fit nicely into the dowel hole.
The starting lengths of the dowels are 24 5/8” and need to be reduced on each end.
All suggestions are welcome. I ask buying a lathe is my last option.
10 replies so far
10250 posts in 3611 days
#1 posted 06-18-2012 06:40 PM
You can do it on the table saw with a round tenon method.
Pretty easy.
View Murdock's profile
Murdock
128 posts in 2447 days
#2 posted 06-18-2012 07:16 PM
+1 for the table saw have done it a few times myself
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
View ksSlim's profile
ksSlim
1274 posts in 2853 days
#3 posted 06-18-2012 10:18 PM
Ditto tablesaw/round tenon. Or with hand tools, score the shoulder and use shoulder plane or chisel, turning dowel while holding tool.
-- Sawdust and shavings are therapeutic
View Ryan Haasen's profile
Ryan Haasen
385 posts in 2364 days
#4 posted 06-18-2012 11:00 PM
I like that router jig!
-- Ryan
View Oldelm's profile
Oldelm
75 posts in 2139 days
#5 posted 06-18-2012 11:40 PM
There is a tool called a hollow auger that was used primairily for wood wheel spoke. I picked one up at a farm sale about 15 years ago for 5 bucks. It works with a brace and does a good job if the cutter is sharp and you don’t try to hog off a lot. Going from 1 to 15/16 is fairly easy. I checked e bay and saw a few, very pricey. I didn’t realize I owned some gold. They do make a similar thing for making “rustic furniture”. I do not have experience with those tools. I like the router jig also.
-- Jim, Missouri
View mtenterprises's profile
mtenterprises
933 posts in 2656 days
#6 posted 06-19-2012 12:33 AM
I have used all these methods. Router or table saw both work about the same way and work well, I’d use a large dia. router bit or my dado head. But the hollow aguer now that’s the way to go. To get them to start you do need to put a slight tapper on the dowel, at least that’s the way mine works.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View chrisstef's profile (online now)
chrisstef
17305 posts in 2970 days
#7 posted 06-19-2012 12:38 AM
any way you could chuck it in your drill press?
View Dallas's profile
Dallas
3599 posts in 2451 days
#8 posted 06-19-2012 12:52 AM
Drill a hole in a piece of steel 31/32” or even better 61/64” twist 1” dowel through the hole.
Cheap, easy and using the little bit of larger diameter allows you to have a tighter fit or sand it down to be perfectly sized.
Good Luck!
BBOSIDE
#9 posted 06-19-2012 01:15 AM
Thank you all for your help. I will try it on my table saw with a stacked dado.
View rance's profile
rance
4255 posts in 3124 days
#10 posted 06-19-2012 01:34 AM
I saw a guy do it on a bandsaw one time. Easy, cheap, and works a treat:
Start by adding a sacrificial fence on your bandsaw fence. Adjust your fence next to the blade(1/32 in your case). Slowly feed the dowel into the blade, rotating it clockwise. A stop block could be used to set the depth to your 1” requirement.
