Help Me Out With A Grill Cart...
Forum topic by RobH posted 90 days ago 145 views 0 times favorited 3 replies Add to Favorites
View RobH's profile
RobH
289 posts in 530 days
90 days ago
Hello all,
I am just getting back into woodworking after a couple of month hiatus. I was inspired by the Big Green Egg cart that Sawdustonmyshoulder posted earlier. See below for a link.
Click for details
I want to build something similar for a Weber kettle grill. My only problem is that I do not want to burn down the deck with it. I am afraid that the grill will get too hot and catch the table on fire. Has anyone got any ideas on how to get this to work?
One idea I have had is to fabricate a ring that will stand off from the edges of the hole, say 2-3”. The ring will attach to the table with some small rods over to the wood. I am thinking this would not get nearly as hot.
Once again, any ideas would be appreciated.
-- -- Rob Hix, King George, VA
View ZachM's profile
ZachM
29 posts in 186 days
90 days ago
I’ve been thinking of doing the same thing with my knock-off weber. I’m thinking I’ll probably just make a side table that will butt up against it on one side, possibly attaching where the screw holes for the handles are.
Since a real weber has welded handles instead of screw on ones, you may need to make holes on one of the sides that doesn’t have a handle already.
If you are looking to make a drop in table like sawdustonmyshoulder, i’d think leaving and inch or two would be enough distance – how ever far your handles are away from the grill should be enough I’d think, although weber uses a plastic composit and not wood for the handles – my knock off and others use wood sometimes with about 1 1/2 inch standoffs separating the wood from the kettle.
View Dadoo's profile
Dadoo
1536 posts in 471 days
88 days ago
I built my old propane grill into a deck table and it worked real well, and lasted for years. Give the grill a 2” gap between itself and any wood, and line the wood surface with tin. I supported the grill on metal fence stakes. The tin lining was just sheet metal. No problem!
View SawDustnSplinters's profile
SawDustnSplinters
107 posts in 262 days
88 days ago
Tile and flashing make a good heatshield, maybe do half tile top and half cutting board top…with side box for the spices and hooks for implements…
-- Frank, Little River/Academy, Texas , http://www.allthingsrustix.com
Bookmark And Share This Page
