Barrel Hinges
Forum topic by scubadver posted 146 days ago 196 views 1 time favorited 5 replies Add to Favorites
View scubadver's profile
scubadver
14 posts in 540 days
146 days ago
does anyone have any tips on installing mini barrel hinges – specifically in a pen box? I know it takes a 45 degree bevel but I can’t seem to get the position, depth etc right for the lid to open correctly
Thanks
-- Gary, Michigan
View Woodhacker's profile
Woodhacker
686 posts in 260 days
146 days ago
Gary, I don’t have any specific guidelines, I’ve done it a few times, but it was mostly just “trial and error”. In the one linked below I had to get pretty close to the edge, and yes, I had to put a small 45 degree bevel…if I recall correctly I think it was just over 1/8 inch wide.
I hope this helps…barrel hinges in pen box
-- Martin, Kansas
scubadver
145 days ago
thanks – I’ll give it a shot
-- Gary, Michigan
View odie's profile
odie
824 posts in 377 days
145 days ago
Gary, I use these things ALL the time, and on many pen boxes. I drill the holes about 1/4” in from the edge. When I bevel the edge I go just a “hair” past the center of the hole from the outside edge. Seat the hinge so the hinge pin is even with the wood and only the round part is showing. And make sure the hinge is perpendicular to the box edge. Let the epoxy dry before you attach the top. Since nothing is perfect in this world, I always make the pen boxes a little larger. After the glue sets up I true everything up as one unit.
I also find that it is more comfortable to take the pens out of the box if the pen slots are 3/4” from the hinge edge of the box. Good luck ….....
-- Odie, Confucius say, "He who laughs at one's self is BUTT of joke".
scubadver
145 days ago
Odie – thanks for the tip. Your instructions were graet and I was able to position the hinges the 1st time I tried. I hinged 4 pen boxes in no time at all. I’ll be off to buy more hinges tomorrow and load up on boxes. Sure wish I could make a living at this rather than a hobby. Sure would beat working.
Thanks again
-- Gary, Michigan
View Chris 's profile
Chris
1259 posts in 528 days
144 days ago
Wow great Tip!!!!
-- Chris
Bookmark And Share This Page
