Help Required - Template needed
Forum topic by MichaelAgate posted 06-17-2012 11:12 PM 1047 views 0 times favorited 11 replies Add to Favorites Watch
View MichaelAgate's profile
MichaelAgate
398 posts in 2322 days
06-17-2012 11:12 PM
Topic tags/keywords: face plate sonata accoridan button holes
Hi everyone,
My Father-in-Law has an accoridan. Llike the one pictured here. The black faceplate around the buttons is missing. I need to make him one but not sure how to get the button holes placed correctly. Any ideas?
Thanks Everyone
-- Michael and Matthew
11 replies so far
View Howie's profile
Howie
2656 posts in 2922 days
#1 posted 06-18-2012 01:56 AM
I’d do a lay out on paper first. Then make a template.
-- Life is good.
10396 posts in 3647 days
#2 posted 06-18-2012 02:35 AM
I assume you mean the cover on the bass side.
Measure the spacing with calipers, lay it out on paper with
a grid and center punch onto the plastic or thin plywood
you’ll be using. Drill with a brad point bit using a backer board.
MichaelAgate
#3 posted 06-18-2012 02:38 AM
Howie, Loren, Thanks guys. I guess it will be a bit of playing around, but will eventually get it. Thanks for the thoughts.
View rance's profile
rance
4258 posts in 3159 days
#4 posted 06-18-2012 03:18 AM
Fashion 20 little wooden washers that fit tightly around your buttons, but that do not interfere with each other. The ID is critical, the outer diameter & shape is not. Lay them over all the buttons. Now lay bamboo skewers(or something similar) along the row of keys, resting it on all those washers. Now use hot melt glue to fasten the wooden washers to the skewer. Three skewers should do it. One on each side and one right up between the buttons. Careful to not get glue on your accordian. What you have made here is a very delicate template.
Now you need to make a sturdy template. Once the glue has cooled down. carefully remove the temporary template and lay it out on a piece of 1/8” plywood. At this point you could hot glue it to the plywood. Now use all those washers to mark and/or drill holes in what will be your sturdy template(the 1/8” plywood). After all the holes are drilled, you can remove the temporary template and throw it away.
I can draw this up in SketchUp if this is confusing.
117091 posts in 3576 days
#5 posted 06-18-2012 03:30 AM
How about just taping a piece of paper over the buttons and do a rubbing with a pencil over the buttons and trace the outline of the keyboard then spray glue it to a piece of 1/4 ply drill and cut it out and you have a pattern.
#6 posted 06-18-2012 03:56 AM
...Or press a piece of styrofoam onto the buttons to take an impression…
I know quite a bit about accordions. The cover is mainly to keep
dirt out of the action. The metal button posts can be bent a
little to travel well through the holes in the cover plate. About
1/16” oversized will allow enough wiggle room that the buttons
should be tweakable to all operate smoothly.
MichaelAgate
#7 posted 06-19-2012 01:15 AM
a1Jim – Excellent idea. I can see that working very well. Will try this tomorrow. Fantastic.
Loren – Nice to know about the 1/16th wiggle room, thanks much.
Thanks everyone!!!
MichaelAgate
#8 posted 06-19-2012 01:17 AM
Rance – That is a fantastic idea as well. I am going to give the paper and pencil a try first but if this fails, I will give your idea a go. That seems to be a fantastic solution as well. Thank you kindly. That’s why it’s nice to ask questions here.
Loren – Styrofoam is great idea as well. I like that also.
View Planeman40's profile
Planeman40
1176 posts in 2760 days
#9 posted 06-19-2012 03:54 AM
a1Jim beat me to it.
I use the “paper & pencil-rub” method all the time around my shop. Quick, easy and accurate!
Planeman
MichaelAgate
#10 posted 06-20-2012 08:05 PM
My wife has given me another fantastic idea. Tape Thumbtacks upside down on the buttons and press a sheet of paper on to them.
The paper and pencil trick worked quite well :)
MichaelAgate
#11 posted 07-27-2012 12:31 AM
I ended up going with Loren’s idea. couldn’t find my callipers so I made another set. Here is the template for the accoridan and the calliper. Now to find some rigid 3/32nd plastic for the actual replacement.
