Removing motor from Dewalt 740 radial arm saw
Forum topic by WaterMonkey posted 06-16-2012 06:28 PM 3021 views 0 times favorited 3 replies Add to Favorites Watch
View WaterMonkey's profile
WaterMonkey
15 posts in 3584 days
06-16-2012 06:28 PM
I was given a Dewalt 740 RAS with a burned out motor. I am trying to remove the motor and I can’t figure out my next step. I have removed the outer casing and removed every screw I can find. The motor will not come off and I am trying to figure out what is holding it in place.
Thanks.
3 replies so far
View roofner's profile
roofner
122 posts in 2245 days
#1 posted 06-16-2012 06:42 PM
Maybe those studs about 2/3 of the way down mayre have nuts on the backside of the housing?
WaterMonkey
#2 posted 06-17-2012 01:10 AM
Actually, they just slide into two holes on the front side of the housing. I started to hit them, from the reverse side, thinking they were stuck. They actually shift about 1/4” in the holes. The whole motor slides back-and-forth on the shaft about a 1/4”. I was thinking the bearings at the end need to come off, but I cant just pull them off.
Here is an image of the other side of the motor
View Loren's profile
10241 posts in 3610 days
#3 posted 06-17-2012 02:05 AM
Ask on OWWM.com
