Water based urethane, how many coats to get a great finish???
Forum topic by Michigander posted 369 days ago 1171 views 0 times favorited 7 replies Add to Favorites Watch
View Michigander's profile
Michigander
101 posts in 617 days
369 days ago
My cherry TV cabinet staining came out well. I have put 5 coats of General Finishes High Performance Polyurethane on it and it looks great. How many coats should I put on for the best protection, without becoming visible (as in plactic looking).
Thanks,
John
7 replies so far
View Clint Searl's profile
Clint Searl
884 posts in 559 days
#1 posted 369 days ago
You’ve already gone two coats more than needed. Why more?
-- Clint Searl.............We deserve what we tolerate
View Milo's profile
Milo
813 posts in 1517 days
#2 posted 369 days ago
I agree with Clint. Three coats should usually do the trick.
Remember to give the finish time to cure before you put anything on it! It takes time, up to 30 days.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View Lee Barker's profile
Lee Barker
1910 posts in 1048 days
#3 posted 369 days ago
What sheen?
I use GF WB Semi Gloss poly on my instruments. I’ve found that the build doesn’t really show any depth until I get to 6 or even 7. I use a Gramercy brush from Tools for Working Wood= and it’s worth every penny. I get a thin coat that’s very even. Recoat in 2 hours.
I let it sit a week before I rub it out. This particular procedure, for both bodies and necks, has evolved over the years and acts just like I want it to.
I hope this helps, though it is not a direct answer to your question.
Kindly,
Michigander
#4 posted 367 days ago
Sorry for the delay in getting back here; been away from the computer. Thanks for the input guys, the sheen is is satin and I am pretty satisfied with the way it has turned out. For the box components I am less concerned with getting depth but more bruise protection. As this is a TV cabinet, components will be slid on the shelves and cables bumping around etc, so I want to protect from that. As for the top, I would like the protection as well as depth as the top will be solid cherry.
Thanks for your input.
John
View killerb's profile
killerb
147 posts in 596 days
#5 posted 367 days ago
More coats will not make the finish harder. It just makes it thicker. As the others have said, 3 is fine. bob
-- Bob www.bobkloes.com
Michigander
#6 posted 366 days ago
Thanks Guys, appreciate the help.
John
View Arvid's profile
Arvid
17 posts in 1208 days
#7 posted 366 days ago
The number of coats really depends on the application method. With a brush, I usually stop at three as mentioned above, but it I spray or wipe on a finish I normally go higher. The other thing to mention when using water based urethane, I normally start with a base of dewaxed shellac for color/warmth then at the urethane for protection.
-- Arvid, Washington DC
