| Forum topic by Ryan522 | posted 343 days ago | 972 views | 0 times favorited | 21 replies | ![]() |
343 days ago |
Hello there, I brought a hammock from a trip from Brazil and I was wondering If I could hang it on those wood beam? I know that the hanger looks very old and weak, that’s why I’m here. Thanks for your help ! |
21 replies so far
#1 posted 343 days ago |
Id hang a hammock off of those beams if it were at my house. Id probably use a lag bolt with an eye hook on the end right into the center of that beam. 800 lbs? you planning on having a party in that hammock? ;) -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#2 posted 343 days ago |
We need three bits of info to give a good answer: 1. How fat are you? Sorry, I couldn’t help it! I think it should be just fine. Those joist hangers are super strong! -- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
#3 posted 343 days ago |
Thank you for your reply Chris, and I would consider doing some changes, but it’s a rented house. I just need an answer from a specialist saying that it would be safe or not. anyone? |
#4 posted 343 days ago |
You’ll be putting just part of the load on this hanger, given the beam is also supported at the other end somewhere. Shear strength of a single nail is into the thousands of pounds, and you are very unlikely to put much stress in the direction that would pull them out of the wall. As long as the wood isn’t rotten, I’d say you’re ready to lounge. |
#5 posted 343 days ago |
1. I’m 162 and my wife is 140.. about 300 hahaha… Should I just try and see what happens? Is there any way to test those hangers? |
#6 posted 343 days ago |
You could probably find some specs for such bracket on the label in hardware store. But at least replacing nails with screws would help. |
#7 posted 343 days ago |
Thank you 1stmistake ! |
#8 posted 343 days ago |
Just look on the bright side. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#9 posted 343 days ago |
Thank you Viktor, that’s a really good idea ! |
#10 posted 343 days ago |
i think youre good to go, youd have to pull out 8 nails taht im asssuming are about 2 1/2”, if it were to go it would be a slow and gradual thing so youd see the nails pulling out. For the rest of the group in terms on shear strength i always thought nails were better than screws? -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#11 posted 343 days ago |
For once I’m going to beg to differ a bit with Viktor. Not all screws are suitable for structural applications and would violate building codes if used on that bracket. At least that is my understanding. The big-box stores carry Simpson Strong-Tie products, and they have nails and screws specifically designed for these kinds of applications. -- Greg D. -- the price of freedom is tolerance |
#12 posted 343 days ago |
Maybe if you posted a photo of yourself and your wife we could tell you for sure. :) Just keep a cell phone in your pocket. If you fall, call 911. I called them yesterday when McDonalds messed up my order. They were very helpful. -- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
#13 posted 343 days ago |
I don’t know about building codes, but obviously you need to use appropriate screws (not drywall screws). I don’t trust nails because they loosen over time. The reason this topic attracted my attention in the first place is because recently I was replacing similar bracket on a very similar beam that was even less exposed to the elements for +15 years. I could easily pull the nails with pliers with one hand. |
#14 posted 343 days ago |
Well you could get some maple rod and weld it to the house. :-) -- Don't rollerskate in a buffalo herd |
#15 posted 343 days ago |
Those hangers are designed to carry vertical, dead loads. If nailed correctly, it would probably be fine, but I sure wouldn’t bet much on them standing up to an oscillating live load (i.e. actually swinging in the hammock). -- Adversity doesn't build character...................it reveals it. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
