I have been working on a house for the last three years. We have a double sided (not through type) fireplace separating the living room from the dining room. You can walk completely around the fireplace. I will try to post some pictures of it tonight. I have the top shelf framewoork done and the top tiled. I also have walls built around the old brick chimney (the masonry was not well done at all). I still need to build around the bottom brickwork (also not well done). Instead of rebuilding the fireplace, I decided to cover it up. I would like a little help with this from all of you master craftsman and designers. I am at a loss. I would like it to be simple, but incorporate some HIDDEN storage for household valuables (to include a few rifles and handguns). Also, I live in Podunk, Mississippi and our most stocked lumber yard is a Lowe’s. That means I have access to a ton of exotic woods like red oak, cedar, pine and MDF. I’m not fond of pine or MDF for anything, but have to settle with the oak and cedar. I
I would like some sketches to choose from if you wouldn’t mind. Maybe incorporate a few designs. I would like to keep it somewhat simple as the house is simple. I think something too fancy will detract. Again I will post some pictures of what the fireplace looks like this evening if I can figure out how.
-- A carpenter takes an ugly, knotted, twisted piece of wood and makes something beautiful and pure from it. Jesus was and still is a carpenter, I am that piece of wood.
This is an older picture while we were getting all the white, brown, red, and more white paint off. It will give you an idea. It is the same on both sides.
The fireplace is 67 5/8” wide X 58 1/4” tall
The opening is 33 1/4” wide X 26 1/4” tall.
Nothing on it is strait. One side angles in, the bricks are not flush, etc. This will be a nightmare at best. The fire opening is dead center, some of the picture was cut off.
One requirement of these old-style fireplaces is that they had to be drafty. (Modern fireplaces have seperate combustable air supplies and circulating air supplies.)
This creates an issue for you to close it up and try to store something of value inside the space. Unless you can seal this up above the roof, this space will be essentially exposed to the elements.
If you could safely dismantle this and close the roof completely, you would solve a lot of issues, not to mention you could reclaim the space to do with as you wished. It would be very messy, but maybe worth it.
I want to still be able to use the fireplace. I am trying to cover up most of the brick and cinder blocks with something like a fireplace surround, but I want to be able to “hide” stuff in the surround. Maybe columns and shelves and such. I am not trying to seal up the fireplace by any means.
Well, that is another matter altogether. (I should read more carefully. Must be something about Friday afternoon.) Usually a non-combustable tile border of about 6” to 8” around the opening is all that is needed then you can put whatever casework seems appropriate. I would integrate a mantle with the casework and perhaps some columns that extend to the ceiling.
I might be a little confused about what you’re trying to do….from the pic shown, I don’t see any reason you can’t build a simple mantel with surround that would cover the bricks and provide at least some storage if you build it out from the wall a little, though you wan’t too have much room in the pilasters (vertical support legs).
I’ve built two mantels, one with shelves, one without ....both with space to hide stuff just underneath the mantel, and both come out from the wall 6” to 8”. To get ideas, we Googled fireplace pics, mantel pics, etc., and made a folder of things we liked. Good luck, and please keep us updated.
8791
220
28
61
79
1530
3547
15768
2034
495
2837
808
901
766
2740
1547
6157
