Flat Panel slot size?
Forum topic by mbs posted 337 days ago 544 views 0 times favorited 5 replies Add to Favorites Watch
View mbs's profile
mbs
966 posts in 1105 days
337 days ago
I have 3/16” thick plywood panels to put in the dado on bi-fold doors. Would you use a 1/4” BitTorrent make the dado or would that be too sloppy of a fit? There aren’t too many options for a 7/32” bit since I need to use a slot cutter with a pilot bearing.
Thanks
-- Sorry the reply is so long. I didn't have time to write a short reply.
5 replies so far
View LeeInAZ's profile
LeeInAZ
31 posts in 640 days
#1 posted 337 days ago
Easiest way I can think of is to make the cut in 2 passes on a router table. Use a 1/8” bit and make the first cut, then raise the bit 3/32 (or whatever your test cut determines to be the best fit), and make a second cut. If you have one of those digital height gauges, it is easy to make this a repeatable setup – just keep a record of the 2 heights.
Another way would be to make the slot 1/8” and then use the slot cutter to trim the thickness of the edge of the plywood panels just far enough back from the edge that it is entirely hidden in the groove. This would give a tight fit even if there was some slight variance in the thickness of the plywood.
-- Lee - Phoenix, AZ
View RussellAP's profile
RussellAP
2394 posts in 451 days
#2 posted 337 days ago
I think you’ll need more band width for a “1/4” BitTorrent”.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View mbs's profile
mbs
#3 posted 336 days ago
I was trying to avoid making multiple passes but I think it’s the best way to do it.
thanks.
View renners's profile
renners
1871 posts in 1134 days
#4 posted 336 days ago
You could do that with a biscuit jointer router bit in multiple passes.
You’d find uses for the biscuit jointer bit after your job is done.
-- Do or do not, there is no try
LeeInAZ
#5 posted 336 days ago
Another option would be to get Freud’s adjustable tongue & groove bit set. It adjusts for grooves from 7/32-3/8
