Box Joint Tip
Forum topic by gfadvm posted 06-15-2012 01:39 AM 1123 views 0 times favorited 5 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2591 days
06-15-2012 01:39 AM
Topic tags/keywords: tip box joint jig set up
There has been a lot of recent interest and discussion of box joint jigs and how finicky/tedious they are to set up. I very meticulously set mine up the FIRST time and then cut some very hard wood scraps tweaking it until I get perfect joints. Then I keep the perfect pieces and just use them for subsequent set ups. No measuring or fussing. I hope this helps someone.
5 replies so far
View Fuzzy's profile
Fuzzy
297 posts in 3890 days
#1 posted 06-15-2012 02:13 AM
WAY TOO SIMPLE … gotta buy some high $$$$$$ jig … SHOOT … let’s just save up a BIG bunch of $$$$$$ and go CNC …
Oh … that IS a great tip, and one I’ve used for decades … thanx for bringing it up. Setup bars/blocks/samples are always a time-saver.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View Roger's profile
Roger
20904 posts in 2705 days
#2 posted 06-15-2012 02:33 AM
Absolutely a fine idea Andy. A setup block per-say. Yup
gfadvm
#3 posted 06-15-2012 03:00 AM
But better than set up blocks/bars because it straddles the index pin and BOTH sides of the blade or bit!
View AlaninlittleWash's profile
AlaninlittleWash
13 posts in 2267 days
#4 posted 06-15-2012 03:27 AM
That technique will certainly work. The more care you take in jig construction and setup, the better chance you have of success.
Remember, however, depending on the jig and what cutter you use (dado on a tablesaw or straight bit on a router table), you may have 3 settings to make- (1) cutter size (same chippers, same shims, carefully stacked with the same torque on the arbor nut), (2) guide pin width, and (3) spacing between the guide pin and cutter. A carefully constructed and calibrated jig can give bad fitting joints if the cutter is not the same size. Plus, you may need to set everything each time you change finger sizes.
View Theron's profile
Theron
24 posts in 2133 days
#5 posted 06-15-2012 01:51 PM
The problem is that if I ever get perfect pieces, I would probably frame them.
-- Theron W., Enid, OK
