production drilling question?
Forum topic by triw posted 06-14-2012 09:17 PM 893 views 0 times favorited 4 replies Add to Favorites Watch
View triw's profile
triw
36 posts in 2337 days
06-14-2012 09:17 PM
I recently received an order for 100 pens made out of mullberry. I was drilling the blanks (new 27/64 drill bit) after about 10 to 15 I could feel the blanks getting very warm and the bit was hot. I drill on my lathe and drill in about 3/4” and back out. Any good ways to keep my drill bit from losing it cool?
View ajosephg's profile
ajosephg
1880 posts in 3590 days
#1 posted 06-14-2012 09:32 PM
1. Back out more frequently, like 1/4 to 3/8.
2. Rig up a nozzle to blow continuous compressed air on the drill bit and pause for 10-15 seconds every time you back out, to further let it cool off.
-- Joe
View PurpLev's profile
PurpLev
8536 posts in 3677 days
#2 posted 06-14-2012 09:39 PM
for high production you might also want to look into HSS or better yet Cobalt drill bit which can run at higher temperatures without losing it’s edge.
Edit:
Also, at what speed are you drilling? you might want to consider reducing it to induce less friction heat to the process as well.
View Gshepherd's profile
Gshepherd
1727 posts in 2230 days
#3 posted 06-15-2012 08:46 AM
Heat buildup will kill any sharp edge. Slow it down some like purp mentioned. Guys all day long can drill through steel and with the right feed rate and speed and a little oil will preserve the bit. The wood will actually cool the bit if it is not fed to fast and correct speed and back out more often to clean the chips out…..
-- What we do in life will Echo through Eternity........
View waho6o9's profile
waho6o9
8209 posts in 2605 days
#4 posted 06-15-2012 11:49 AM
+1 for PurpLev, Cobalt totally rocks, use machine grade cobalt bits and you’ll be fine.
