| Forum topic by hplotts | posted 342 days ago | 463 views | 0 times favorited | 4 replies | ![]() |
342 days ago |
I am restoring a 8” Craftsman 101-02142 and am in need of an original motor mounting bracket and was wondering if anyone can help locate one? |
#1 posted 342 days ago |
Have you looked on VintageMachinery.org? I couldn’t find a manual for your model, do you have one? Check out these pdf Sears Tool Catalogs from the Vintage Machinery site. 1938, 1939, 1940, 1941, and others . I think your saw should be in at least one of them. I don’t know what you mean by a mounting bracket. My old motors have mounts cast onto them. You would bolt the motor behind the saw or under it on a shelf (with a hole for the belt). -Jack |
#2 posted 341 days ago |
Thank you for your reply. I have attached a picture of the only part I need but not sure what it is called. |
#3 posted 341 days ago |
You may have to have one fabricated if you don’t have the capability to make one yourself. A piece of 1/4 inch steel plate with hinges welded on each end will work just fine. For a saw that old you probably not be able to find the part. Good luck. -- Carl in SC |
#4 posted 341 days ago |
I’m assuming that saw has a tilting arbor, hence you can’t just mount the motor to a stand as suggested. Post a wanted in the classifieds of Vintage Machinery site – people part out small saws like that all the time. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15786 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
