Your advise please!
Forum topic by thetimberkid posted 510 days ago 227 views 0 times favorited 11 replies Add to Favorites Watch
Rockler
View thetimberkid's profile
thetimberkid
1944 posts in 603 days
510 days ago
Topic tags/keywords: question bandsaw
I was wondering if any of you have any advice on buying a good sized band saw. I am looking to spend the eqivelent of about $500-$600, what do you think i should expect features and quality wise on a saw that costs this much. Also any saws that you would recomend in this price range would be appreciated!
Any ideas ?
Thanks
Callum
20805 posts in 722 days
510 days ago
In this price range you can get a decent 14” band saw. There have been several reviews posted here. I would not go with anything less than a 1 hp motor and an included dust port would be nice. You should also get a riser block as well. This will enable you to resaw boards if you need to.
teenagewoodworker
2482 posts in 668 days
510 days ago
i think you could get a good jet bandsaw for that kind of money. you should check out their models. i think they have 3 14” models so you should be able to find what you need in that price range from them.
View lew's profile
lew
4515 posts in 655 days
510 days ago
Definitely agree with Scott. The riser block will boost up the resaw capability. Also, look into adding Carter type bearing to replace the blade guides.
Dick, & Barb Cain
7050 posts in 1199 days
510 days ago
Check out the band saw reviews on Lumberjocks. here’s my Rikon review.
View marcb's profile
marcb
705 posts in 573 days
510 days ago
My advice, after you get your bandsaw, is to stay away from snake oil. Carter anything, quick release anything. Good solid tool steel guides out perform everything else.
I’ve resawn 7” cherry with 3/4 horsepower with a well setup saw with an old blade that has never been detensioned in its life using OEM blade guides.
Everyone I’ve talked to that has these seems to have more issues than I do, cognitive dissidence tells them they don’t. Of course they use linkbelts on everything because a $40 belt has to be better than my $7 gates.
View John Gray's profile
John Gray
1757 posts in 785 days
510 days ago
March sure has a point there. I purchased a Kreg fence and otherwise mine is stock facrory and works great for me.
14949 posts in 751 days
510 days ago
Callum, if you get one that accepts a riser kit it will give you the potential to cut deeper. If you can’t afford it now you could add it later.
Get one with a good fence,it makes a lot of difference.
View odie's profile
odie
1603 posts in 740 days
510 days ago
I will tell you this …. ” I WILL NEVER BUY GRIZZLY AGAIN” ... end of story …......
View grumpycarp's profile
grumpycarp
232 posts in 646 days
510 days ago
I saw that you were seeking opinions on table saws as well and I was going to advise you to spend your money on a band saw instead. So here it is . . . spend your money on a band saw. 600 bucks American is probably a little light for a good one so you might consider waiting on the t/s to maximize your bang for the buck.
If I were just starting out I would definitely buy a band saw first . . .
View motthunter's profile
motthunter
2079 posts in 699 days
510 days ago
Your best option at this price would be the grizzly. Save a little more and you can get a lot more though.
-- making sawdust....
View SteveKorz's profile
SteveKorz
2030 posts in 614 days
509 days ago
Follow Dick Cain’s advice. Save up and get a Rikon. I just bought one, the same in Dick’s review, and it is terrific! The saw cuts thru 14 inch oak like it’s a marshmallow. It’s got a 14 inch resaw capacity. The saw has a 1 1/2hp motor. It doesn’t bog down. It was way worth the money. I have no bandsaw experience at all, and I was able to resaw the first couple times after minor adjustments. It truely is a great saw. If you need more, shoot Dick or I an email.
I was going to buy a Grizzly until I started hearing things about their equipment. I don’t know if any of that is true or not, as I do not own any Grizzly equipment. I can vouch for the Rikon though, and it’s one heck of a machine that you will not regret saving for and buying.
