Workshop Electrical Question
Forum topic by Bill Szydlo posted 06-14-2012 03:10 PM 2719 views 0 times favorited 18 replies Add to Favorites Watch
View Bill Szydlo's profile
Bill Szydlo
65 posts in 2711 days
06-14-2012 03:10 PM
I am planning a new shop and am wondering if it’s better to run the electrical wiring in the standard fashion (in the walls) or to run it through conduit along the interior walls? Recently I was looking at a few shops for ideas and noticed individuals that ran the electrical through the conduit primarily in order to gain some flexibility should the layout change in the future. Just curious if anyone has used this approach.
Thanks in advance,
Bill
18 replies so far
View RussellAP's profile
RussellAP
3104 posts in 2310 days
#1 posted 06-14-2012 03:15 PM
I kept mine rated for 20Amps and out where I can see the wire. I use external fixtures (4-plex) and write on each plug what the amp rating is. Be sure to get plugs and switches rated for the type wire you use, there are different fixtures for aluminum and copper, don’t mix them up. And remember all junction boxes need to be exposed, you can’t hide them under drywall. Huge fire hazard.
View SirFatty's profile
SirFatty
542 posts in 2235 days
#2 posted 06-14-2012 03:17 PM
I would think that electrical code in your area should be the guide to follow. Here in the Chicago area, it’s all EMT. Personally, I think it is a superior way to go, but definitely is more work and expense.
-- Visit my blog at dave.spalla.com
View jmos's profile
jmos
839 posts in 2393 days
#3 posted 06-14-2012 03:29 PM
More information would be helpful; Garage? Basement? Detached structure? Finished space? Unfinished?
In general I think it’s helpful to have access to the wiring for future changes. I certainly wouldn’t tear into existing drywall to run wiring in the walls. If it’s an unfinished space with studs it might be worth running it through the studs. If you have access to the ceiling you can run the wire in the rafters to keep it out of the way and then do drops with conduit just to protect the wires (that’s what I did in my basement shop.)
If your doing this yourself without permits you want something you can remove if you ever move. If your hiring a pro I’d let them recommend the method.l
-- John
Bill Szydlo
#4 posted 06-14-2012 03:35 PM
Thanks for writing back. Here is some additional information. The structure is a new addition to a detached garage so I am basically starting from scratch. The existing garage already has a separate 100 amp panel that will be used for the new shop space.
RussellAP
#5 posted 06-14-2012 03:45 PM
It may be code to put everything in conduit, check with the city. If not, I’d leave all wiring exposed and keep the plugs up high. Since it’s only you in your shop, you won’t be running more than one thing at a time, so 100amps is kind of a waste. As the shop evolves, you’ll need access to install or move plugs around.
View jmos's profile
jmos
#6 posted 06-14-2012 03:48 PM
Looking at your other post, I assume your planning on insulating and sheet rocking the walls given your MN climate.
That’s a tough call; I think I would be generous, run a number 20amp circuits (since you have that nice 100amp panel), and run them in the studs before finishing the walls, and add a lot of outlets to give you flexibility. If your planning on running 220v for just a few tools, that might be worth doing in conduit in case you change your mind later and want to reorganize your shop.
These are fun problems to have!
-- John
View helluvawreck's profile
helluvawreck
31363 posts in 2890 days
#7 posted 06-14-2012 04:01 PM
Most of mine is run through conduit on the outside of the walls. I just like it better for a workshop and is easily repaired or modified.
helluvawreck
https://woodworkingexpo.wordpress.com
View Bigjoemann's profile
Bigjoemann
27 posts in 2684 days
#8 posted 06-14-2012 04:25 PM
Outside the walls is OK, just make sure it is in conduit. Whatever you do, make sure to a pull a permit from your local building department. There will almost always be something that you or your electrician missed. What the inspector finds could make the difference between having a house or a large pile of ashes.
If you are going to do something, do it right. No half-assed work when it comes to electrical!
View SnowyRiver's profile
SnowyRiver
51457 posts in 3504 days
#9 posted 06-14-2012 04:34 PM
I ran mine through conduit on the outside of the wall. I only did it that way because I have a wood foundation on the house and shop and there are 2X12 trusses holding up the garage floor laying on 2X12 plates and I didnt want to drill into the plates for structural reasons. I would think running it in the wall would be fine and probably look better. Just plan it out so you have enough outlets including some 220 for larger equipment.
-- Wayne - Plymouth MN
Bill Szydlo
#10 posted 06-14-2012 05:04 PM
Thanks for all the replies. I am leaning toward running the electrical in the walls mainly for a cleaner look to the space. Since the panel is close it would not be difficult to add a line, through conduit, at a later date if the need arises. Now for the 220 lines – since both the TS and jointer will be located in the center of the room and the room is on a concrete slab my choices are limited to either running a conduit along the floor from the wall or dropping the line down from the ceiling. Any opinions would be appreciated.
RussellAP
#11 posted 06-14-2012 05:52 PM
If the TS and Jointer are near a pole just run a 2x strapped to the pole and put an outlet on that from the ceiling.
View ITnerd's profile
ITnerd
263 posts in 2623 days
#12 posted 06-14-2012 07:33 PM
My 2 cents – go with the ceiling drop to the tools in the center of the space. The last thing you want to do have any irregularies in the floor as you feed a long piece through for a cross cut or joint a long edge. I would thing a center drop woule be safest. I would rather bang my head/shoulder than trip, but ideally a well placed center drop would eliminate both risks.
Even if you don’t have a pole there, you could drop in some sort of inverted T to protect the wiring and hold the safety equipment you’ll be using when bossing around the 220v monsters – like Phil B did in his batcave. God, I love that shop.
-- Chris @ Atlanta - JGM - Occam's razor tells us that when you hear hoofs, think horses not zebras.
View Scot's profile
Scot
344 posts in 3420 days
#13 posted 06-14-2012 09:43 PM
Both electrical and dust collection drop from the overhead on my saw.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View AandCstyle's profile
AandCstyle
3069 posts in 2280 days
#14 posted 06-15-2012 12:08 AM
I had duplex boxes installed every 4 feet along all walls 50” off the floor should I ever want to lean a sheet of plywood against the wall. I haven’t yet experienced a “wish I had” moment yet. It is cheap and easy to do during construction, but not afterward. I put ceiling plugs in for tools in the center of the room. I also put in a ceiling outlet with a cord reel over my workbench for any hand tools I might want to use, e.g. sander, shop vac, etc. HTH
-- Art
View Mainiac Matt 's profile
Mainiac Matt
8085 posts in 2352 days
#15 posted 06-15-2012 12:30 AM
You’ll save a lot of $ & time putting Romex in the walls…. At least for you 20 amp 120 volt circuits and light circuits.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
