What can I do/make out of these? Was hoping for some ideas.
Forum topic by Blackie_ posted 06-14-2012 01:18 PM 1767 views 0 times favorited 25 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4843 posts in 2384 days
06-14-2012 01:18 PM
I have these slabs from spalted hackberry and was hoping for some ideas on what I can do or make out of them, they are 1 1/8th” thick and measure 14” long end and 12” short end, what I’ve come up with so far, table top carousel, small end tables and or a a stool or two, thats about it. Since they have a flat edge not so sure a carousel would work.
Thanks
Blackie
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
25 replies so far
View DamnYankee's profile
DamnYankee
3301 posts in 2433 days
#1 posted 06-14-2012 01:23 PM
Something with endgrain that’s for sure.
-- Shameless - Winner of two Stumpy Nubs Awards
View jusfine's profile
jusfine
2422 posts in 2797 days
#2 posted 06-14-2012 01:26 PM
Glue them together with an alternating darker color, then turn on the lathe, would make an interesting bowl…
Beautiful grain!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Ted's profile
Ted
2838 posts in 2082 days
#3 posted 06-14-2012 01:32 PM
People are always turning bowls.. maybe turning some dinner plates? :D
Okay, just kidding… but it seems a table or stool will be fragile if not backed with something cross grain. How hard is hackberry? Maybe some end grain cutting boards.
-- You can collect dust or you can make dust. I choose to make it.
Blackie_
#4 posted 06-14-2012 01:46 PM
Oop no lathe
Blackie_
#5 posted 06-14-2012 01:51 PM
hmm endgrain cutting board perhaps? I could square up a bit
View Ted's profile
Ted
#6 posted 06-14-2012 01:51 PM
I’ll be keeping an eye on this thread to see what others come up with. After end grain cutting boards, I’m stumped. (pun fully intended)
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2241 days
#7 posted 06-14-2012 01:54 PM
Small bookshelf for trinkets or whatnot. Looks like you’ve got 6 shelves.
Blackie_
#8 posted 06-14-2012 01:54 PM
Actually I wasn’t sure if you could use spalted wood for food products.
Blackie_
#9 posted 06-14-2012 02:01 PM
Great Idea Ed, thanks
For the supports I could use either Walnut, Alder or Maple, brown maple might go well here.
View YorkshireStewart's profile
YorkshireStewart
1130 posts in 3772 days
#10 posted 06-14-2012 05:47 PM
I’ve no idea about Hackberry as such, but depending on how dry the slices are already, I’d be seriously concerned about future radial splitting as drying takes place.
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
Blackie_
#11 posted 06-14-2012 06:13 PM
stewart, I have the air drying stickered now, I’m thinking a month they should be ready, hopefully they’ll keep their form without splitting.
View Doss's profile
Doss
779 posts in 2136 days
#12 posted 06-14-2012 06:44 PM
I’m not going to say that they will split, but… they will split (if they’re still wet right now). From the looks of it, it’s already starting.
I have had a few different types of slices like that at different thicknesses and they all ended up splitting eventually. You might want to read what the turners do to insure that the pieces don’t split. I don’t really need cuts like that so I just chalked them up to experimental pieces and moved on.
As for other ideas, they can be used for inlays, small boxes, serving trays, umm…. can’t think of anything else right now.
Good luck on drying those.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View PurpLev's profile
PurpLev
8534 posts in 3520 days
#13 posted 06-14-2012 06:49 PM
a seating set – as the seat itself…
View bondogaposis's profile
bondogaposis
4525 posts in 2222 days
#14 posted 06-14-2012 06:51 PM
Clock faces, and yes they are going to split.
-- Bondo Gaposis
Blackie_
#15 posted 06-14-2012 10:01 PM
I’ve read up on soaking them in denatured alcohol, supposed to replace the water and keep them from splitting.
