How many ways
Forum topic by sandhill posted 06-13-2012 11:24 PM 1266 views 0 times favorited 7 replies Add to Favorites Watch
View sandhill's profile
sandhill
2128 posts in 4158 days
06-13-2012 11:24 PM
Topic tags/keywords: tip question joining
I use Mortise & Tenons as joinery for my arts and crafts furniture and its seems pretty straight forward. But then I got to thinking (think, think, think). There has to be more then one way to use these clever joints how many ways and types and uses of Mortise & Tenons are there uses for?
EXAMPLE: Draw board Tenon USE: Make a tenon draw tighter and gives more strength.
7 replies so far
View oluf's profile
oluf
260 posts in 3273 days
#1 posted 06-13-2012 11:32 PM
Wedged tennons. Both blind and exposed.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View knockknock's profile
knockknock
462 posts in 2408 days
#2 posted 06-14-2012 01:02 AM
Half dovetailed wedged through tenon, when you want to lock a rail to a post and be able to take it apart again.
sandhill
#3 posted 06-29-2012 03:06 AM
Well I guess not many woodworkers use them.
View OnlyJustME's profile
OnlyJustME
1562 posts in 2611 days
#4 posted 06-29-2012 04:42 AM
I’ve always liked the look of the wedged through tenon. Used for stretchers between table legs.
-- In the end, when your life flashes before your eyes, will you like what you see?
View Woodbum's profile
Woodbum
846 posts in 3300 days
#5 posted 06-29-2012 07:41 PM
Haunched?
-- "Now I'm just another old guy wearing funny clothes"
sandhill
#6 posted 06-29-2012 08:49 PM
Woodbum I like haunched tenons because they resists “racking”, I was considering using them for cabinet doors with pins for decoration. The other reason is you can just lower the bit/blade to ad the recess for the panel and avoid stop cuts. I think it would look good on shaker doors because there are no raised panels and would give maximum strength. OnlyJustME They do look good and are great if your building Knock down furniture and as KnockKnock said “Half dovetailed wedged through tenon” show craftsmanship and provide a stronger joint.
sandhill
#7 posted 06-29-2012 09:04 PM
Here is one I have never saw before. Hammer-Head Tenon Joint.
