| Forum topic by Sac | posted 61 days ago | 313 views | 0 times favorited | 20 replies | ![]() |
61 days ago |
Hello fellow lumberjocks, My wife has decided that since I can get oak @ $1 a bf from the fellow I got my wood from last week that she wants oak flooring in the living room and hall. I am looking at 450 sq ft with 50 additional allowance. Info on the Oak I would be buying. She asked me some questions I of course couldn’t answer so I thought I would ask all of you, the pro’s. Q’s 2. Should I bevel the sides at an angle? I have already planed on beveling the ends at a 5-10 deg angle. 3. Should I use only glue? Or use glue and finishing nails? Your help is greatly appreciated in all my questions but since she has handed me my first project I would like to get it right since it will be something that we plan on having the rest of our lives. Thanks -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
61 days ago |
No glue. Just nailed. They have a machine just for tjis. You can rent them. Machined tongue and groove – very time consuming. Finished all sides is best- that prevents much of the movement but assuming the room is kept fairly constent, one side finish would be OK. I have a floor down for 20 years that way, no problem. -- Bruce from Central New York |
61 days ago |
Could I dado the tongue and groove or just the tongue and route the groove? Or would it be to inconsistant or more time consuming than a rented tool? -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
61 days ago |
Jerry, If possible “V” groove the flooring. This allows you ro prefinish the flooring so you won’t have to sand it. If the material does shrink it will not be noticeable. There is a trick to machining T & G flooring that helps keep the face joints tight. When you machine the groove cut back the portion below the tongue 1/16”. This guarantees the face side will bump-up tight. I would not use any adhesine to attach the flooring just finish nails through the tongue. Make sure to install some sort of felt/rosin paper or the foam that the laminate flooring people use between the flooring and the subfloor to keep the floor from squeeking, another reason you would not glue down the floor unless of course you are going over concrete. Don’t forget to allow plenty of time for the flooring to acclimate before installation. -- Don, Pittsburgh |
61 days ago |
Jerry, This may be counter productive to your post but planing a 1” board to 1/16” or 1/8” seems like a terrible waste of good lumber, to me. You could get twice the flooring by re-sawing to 1/2” then planing! My 2 cents. Lew |
61 days ago |
Jerry, If you are going to be using this as flooring then you should not be going less than 3/4” for the oak. The purpose of the tongue and groove system is to help conceal the inevitable gaps that will come from normal wood movement. Brunob is talking about a floor nailer as a rented tool. You can rent these either as a manual or as a pneumatic nailer. If you want to buy one Ebay is a good source for these. Wood flooring has a tongue on the left side and the front and has mating grooves on the other two sides of each board. You must nail it down rather than gluing. If you glue and nail the wood movement can cause the boards to split. After it is installed you will need to sand it through at least 120 grit then apply at least two finish coats, usually polyurethane. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
61 days ago |
hi sac hope this helps -- cut it saw it scrap it |
61 days ago |
You could cut the tongue and groove any way you have handy. The tool I was referring to was mentioned by Pommy. It’s for bnailing the floor down. Perfectly placed and countersunk nails every time.. Make sure the tongue is a little less than the depth of the groove. -- Bruce from Central New York |
61 days ago |
I understand you to mean that you’re taking 1/16- 1/8” off of the 1” boards. That will give you nice thick boards to work with. I agree with the nailing that everyone has mentioned. The best time to put this floor down is in the dead of winter. Let the wood acclimate for several days in the heat of the house and it will shrink about as much as it’s going to. Then in the summer when the humidity comes back, it will just tighten everything up. -- Tim -- http://tmuli.com |
61 days ago |
Good Advice from all of you. I thank you. I’ve a pneumatic framing, finish and brad nailer. But I should go rent a bnailer. Ok That shouldn’t be a problem. The thought about felt/rosin paper or the foam for laminate flooring I had no idea about. We have foam for laminate flooring left over from the basement. Would the felt roofing paper be ok? We may just purchase more of the foam. It sounds like it may actually be better than the felt/rosin. I reallt don’t know but just handling the 2 types is a major difference. Yea the flooring will be 4/4 and I’ll plane 1/16 or 1/8 off for the finished side. Should I have to plane both sides? Thanks for your responses. I’ve decided to go a different route on the purchase. I’ll be purchasing the wood from the sawmill down the road. It isn’t alot probably for most of you but for me it seems to be alot. So yes I will rent me a BNailer in 3-4 months. He’s going to cut it this week and I’ll bring it to the house and let it sit for 90-120 days before I install it. He’s also going to cut the spacers as well. I’ll just let it sit and dry here. Could I cut the tongue and grove now or wait till I get ready to install it? Thanks for your responses. Thanks again for your thoughts. -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
61 days ago |
Jerry, I have installed many types of flooring. Just installed some oak flooring for a job on sunday. I suggest you go to a store that sells wood flooring and get a sample of any type of flooring with tongue and groove. You will notice that the shape of the tongue is not a regular straight edge tongue. It is slightly more relieved on the bottom edge. This ensures that the upper sections will mate up with each other tightly. The bottom of the boards have dados which stablize the wood and allow air to move under them. Good Luck -- Oldworld, Fair Oaks, Ca |
61 days ago |
Jerry, I agree with John. -- Grumpy - "Always look on the bright side of life"- Monty Python |
60 days ago |
Thanks folks. We have 2 milling bussiness’s close by and a third a few miles away. I’ll get some pricing from them today. Who knows they may be able to beat the overall price for everything. Anyway looks like my first project will be installed after several other projects since the wood will be sitting for awhile. Thank you all again for the advice and opinions on how to do this. I can’t imagine another resourse anywhere as good as LJ’s! -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
60 days ago |
NewMexico, -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
60 days ago |
Sac, -- woodbutcher north carolina |
60 days ago |
oh cool. Thanks for answering about the 15# roofing felt. I have a couple of rolls left over. 1/2 in on the outside perimiter. ok. I hadn’t thought about the possability of it buckling if I ran it all the way up to the wall which I had planned on doing. Now I know why the oak laminate in the basement is buckling. I didn’t run it. We hired that out and he ran it all to the walls edges. on one wall it is buckling a little bit. I may be mistaking about laminate being able to buckle since I have never laid it before or read about laying it. -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
60 days ago |
Thanks NewMexico, I never took it personal or will take anything here personal unless it is a direct attack which I doubt very seriously will ever happen here at LJ’s. Need Rain. Hot & Humid… :-) -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
60 days ago |
This thread is information sharing at it’s best! -- Don, Pittsburgh |
60 days ago |
Yes it is Don. I consider myself a beginner at woodworking since I really haven’t constructed anything since the early 80’s. Now it has become a fulltime passion. You all here at LJ’s make it even more enjoyable because you do answer my long winded post with your knowledge and experience which I hope to have and be able to share. I print alot of post nad put them in my Note binder in tha garage. I can’t say enough about my appreciation of you folks here. -- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's |
60 days ago |
I would not recommend using 15# felt. You will want to use a thinner paper that is made for hardiboard and wonderboard underlayment and wood floors. It usually is a tannish color. The paper is slicker and allows the flooring to expand and contract. It is much easier to lay down and will outlast us. One other very important thing is to make sure the subfloor is very flat and free of any debris that might cause a plank to be set off of the floor a bit. -- Oldworld, Fair Oaks, Ca |
60 days ago |
Sac, -- www.atlaslumber.com/current-news.asp |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1146 |
1533 |
105 |
301 |
96 |
Woodworking Trade & Swap
211 |
Coffee Lounge
839 |
LumberJocks.com Site Feedback
256 |
