jointer technique
Forum topic by scribble posted 06-13-2012 03:45 PM 1337 views 0 times favorited 6 replies Add to Favorites Watch
View scribble's profile
scribble
196 posts in 2372 days
06-13-2012 03:45 PM
I am having problems when jointing boards on my 6” Delta jointer that I am putting a bevel on the side I am jointing. I know the problem has to be me since the fence and tables are leveled and coplanar. I am wondering if anyone can give me some insite as to what I am doing wrong.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4129 days
#1 posted 06-13-2012 05:12 PM
I’m sure you will get some replies but you need to give more info about what you are doing and how you are attempting to do it..
View chrisstef's profile
chrisstef
17713 posts in 3178 days
#2 posted 06-13-2012 05:16 PM
Is the face of the board that is against the fence flat? If not you will get a beveled edge.
13635 posts in 3513 days
#3 posted 06-13-2012 05:30 PM
when i do beveled edges
i turn the fence to the table side
this ‘traps’ the board into the acute angle formed
with the fence outboard tilt
it can let the board ‘slide’ away from the fence
changing the angle slightly
from the vibration
hope this is what you are asking about
scribble
#4 posted 06-13-2012 05:31 PM
I started by jointing the face if the board but something might have not been flattened correctly. I then jointed the edge with the jointed face against the fence.
chrisstef
#5 posted 06-13-2012 05:37 PM
Id suggest flipping the piece over and see if you are getting the same bevel on the edge with a different orientation of the board. I can almost feel a “suction” againt the fence when things are jointing properly.
scribble
#6 posted 06-13-2012 06:35 PM
I will try that tonight, the pieces I am using a not thick enough for the intended purpose so I can joint till they are toothpicks.
