Biscuit joiner. Which one?
Forum topic by Charlie posted 339 days ago 1169 views 0 times favorited 26 replies Add to Favorites Watch
View Charlie's profile
Charlie
670 posts in 451 days
339 days ago
I’m going to be edge joining some walnut. I just don’t see a good way to do this without a biscuit joiner.
I can get a Dewalt DW682K for $149 or the PC 557 for $219. Quite a difference in price. Checked Craigslist. Nada. Neither comes with the 2 inch blade for face frames if I decide to go that route in a later project. And I’m assuming neither comes with any biscuits.
Not sure how much use it will get after this kitchen project, but…. I know there’s some things you use more once you have them.
Which way would you go? And please don’t tell me to get a Domino. I’m not shelling out that kind of cash. I just need a biscuit joiner that is accurate and will get this job done.
Making a small counter top. About 24×33. Using Walnut that’s about an inch and a quarter.
Thanks
26 replies so far
View Ken Fitzpatrick's profile
Ken Fitzpatrick
365 posts in 2189 days
#1 posted 339 days ago
I’ve had the DeWalt for a long time and it has served me well. PC makes tremendous products so I guess you do have a delima lol. Isn’t it great buying new tools!
-- • "I have noticed that nothing I have never said ever did me any harm."....... Calvin Coolidge
View AJLastra's profile
AJLastra
86 posts in 394 days
#2 posted 339 days ago
DeWalt. I actually have the Craftsman model which is an exact copy of the DeWalt, made by DeWalt…...go figure. I’ve used it for years with no problems at all. One other thing to consider and thats the biscuits you buy. No kidding. some of these little pieces of wood will drive you nuts because they are not uniformly manufactured so a number 10 or a number 20 isnt truly a number 10 or 20. they will warp and swell just from the air they’re stored in. Porter Cable makes good biscuits and they’re not expensive.
View Fuzzy's profile
Fuzzy
249 posts in 2153 days
#3 posted 339 days ago
I just know you’re going to get a flood of totally unrelated opinions about how worthless the biscuit cutter is, and how it’s just a toy, not suitable for anything of any quality … ... ...
BUT
I have the DeWalt … use it on every project in some way or fashion, and wouldn’t be without it. If the Porter Cable feature of the auxiliary blade suits you, your decision is made. Both are fine products, and should serve you well.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View Mosquito's profile
Mosquito
2754 posts in 457 days
#4 posted 339 days ago
I’ve got the PC 557 and it works quite well. I picked mine up for $189 new plus an 11% off rebate on top of it.
Only comment I have for its use is to not even bother with the dust/chip collection bag that comes with it. It’s useless. It stops most of the chips right at the opening, and so it clogs it up and after about 2 biscuits the sawdust starts coming out around the blade instead. I just use it with out the bag and angle the bag mounting plastic elbow away from me and let it shoot out and away (when I’m working outside).
Edit:
AJLastra has a good point about the biscuits, I always dry fit and often end up trying about 50% more biscuits than I use, just to get ones with good fits
-- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods
View TheDane's profile
TheDane
2672 posts in 1828 days
#5 posted 339 days ago
+1 for the DeWalt … I have had one for about six years. Built like a tank, easy to use, and produces repeatable results.
—Gerry
Charlie
#6 posted 339 days ago
OK well I guess I should ask…. for a counter top this small, do I even NEED biscuits?
Or can I just glue it (Titebond II)?
I can see where biscuits would help with alignment, but…. this is kinda small. And an inch and a quarter thick.
Just one of those things I don’t have experience with… (normal)
thanks
View Tennessee's profile
Tennessee
1089 posts in 680 days
#7 posted 339 days ago
I’ve had my PC for about ten years. Works great every time. If it’s any consideration, I see Dewalt units in pawn shops. Might be a great way to pick up one on the cheap.
-- Paul, Tennessee, http://www.tsunamiguitars.com
Ken Fitzpatrick
#8 posted 339 days ago
Charlie
You don’t really need the BC for what you are doing. Glue should hold it just fine. A belt sander, plane or scraper could clean up the top nice and smooth. The BC would help in alignment , minimizing cleanup but will you use it again? Tools are my toys. I would use one, but that’s me. Your the one who has to be happy.
Glued joints by themselves worked just fine for hundreds of years. Your choice. Good luck.
View crank49's profile
crank49
2276 posts in 1136 days
#9 posted 339 days ago
Pc and Dewalt are the industry standard machines. About a year ago one of the woodworking magazines did a comparison of about 8 machines and those two came out on top. They found the Porter Cable to be the only machine able to correctly joint certain miter joints due to the way its fence is made and it could use the mini size biscuits. Otherwise PC and Dewalt were even.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View knotscott's profile
knotscott
4180 posts in 1541 days
#10 posted 339 days ago
I owned the DW for several years….it’s a good tool, but largely unnecessary IMO. Biscuits aren’t a necessity for most glue hardwood ups if the edges are flat and tight. (The PC has the advantage of be able to cut face frame size biscuits that the DW doesn’t do the last I knew). A router is capable of cutting most biscuit slots for the few occasions I deem them necessary, but there are almost always other methods that are equally good, easier, stronger, or all of the above. Pocket holes aren’t completely interchangeable with biscuits, but I find a good pocket hole jig to be a more useful tool than the biscuit cutter in general.
View knothead's profile
knothead
122 posts in 2113 days
#11 posted 339 days ago
Don’t forget to check Ebay!
I bought the Dewalt (I’m at work now so I can’t remember the model number – but it is current) used from a contractor that bought it then said it didn’t fit his needs like he thought it would. I gave $40.00 plus shipping. It was almost pristine in the case when it arrived and I have been very happy. I rarely use biscuits other than for large panels so it sits idle allot, but for $40.00 it has been a bang up tool.
Shop carefully and Ebay can be your friend
Enjoy!
Chris
-- So Much Wood - So Little Time! --
View Mike's profile
Mike
60 posts in 375 days
#12 posted 339 days ago
What about Makita? I’ve looked at one at HD a few times, seems like a really nice tool. For your intended project, will pocket hole screw work?
View jusfine's profile
jusfine
2152 posts in 1091 days
#13 posted 339 days ago
I have the Dewalt, used it for years without a problem.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Brandon's profile
Brandon
3735 posts in 1117 days
#14 posted 339 days ago
if you’re mostly concerned about the alignment of boards for the top, I’d just drill a couple of holes and use dowels instead. I’d only buy a biscuit jointer if you see a lot of uses for the type of projects you have in mind.
On a side note, I have a Freud biscuit jointer that was given to me. Seems like a decent machine, but I don’t use it all that often.
-- "hold fast to that which is good"
6486 posts in 2145 days
#15 posted 339 days ago
I have a couple Porter Cable machines that hve seena great deal of use. They’ve worked very well for me. I’ve used the Dewalt and the Frued, but like the PC the best.
