When making a table top should I........
Forum topic by Rob Vicelli posted 06-13-2012 02:15 AM 2611 views 0 times favorited 7 replies Add to Favorites Watch
View Rob Vicelli's profile
Rob Vicelli
106 posts in 2931 days
06-13-2012 02:15 AM
Topic tags/keywords: question
I am in need of a little advice. I am building a kitchen table 38×60 with 1 12” leaf. The top is hard maple with a finished thickness of 1 1/8” and the boards run the length of the table and each board will be about 5 7/16 wide. So when getting ready for glue up should I glue them up at full length cut the pieces using a circular saw followed by a trimming up on the table saw OR cut each piece slightly oversize, number their location and glue up?
Just thinking about handling the weight of the full size top to cut it in half and cut the leaf out can be very daunting.
-- Rob V
7 replies so far
View Bobmedic's profile
Bobmedic
382 posts in 3041 days
#1 posted 06-13-2012 02:45 AM
I would glue them up full length then cut out the center leaf and trim the ends to final length. You can do it all with a good circular saw and a straight edge.
View Nomad62's profile
Nomad62
726 posts in 3197 days
#2 posted 06-14-2012 08:50 PM
I agree with Bob, glue it as 1 big piece then slice to make the leaf. It may be a stretch, but if you cut them they may move a bit whereas a glued edge will tend to hold them in place if stress is there.
View Mosquito's profile
Mosquito
9568 posts in 2532 days
#3 posted 06-14-2012 08:56 PM
Another vote for glue then cut, you’ll get a perfect fit that way too
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View Howie's profile
Howie
2656 posts in 3162 days
#4 posted 06-14-2012 09:02 PM
I agree with the others. Glue it up then cut it.
Sounds like a nice project, can you give us some progress photos as you work on it? I’m contemplating my next project being a dining room table.
-- Life is good.
Rob Vicelli
#5 posted 06-15-2012 02:37 AM
Makes sense, Glue up then cut. Thank you for the help. Here are some photos of what I have done so far. I will take more photos from this point forward.
Started with Gluing up blocks for the legs, After realizing I could not taper them on my jointer I had to whip up a taper jig. Found some Ideas I like and combined what I liked for this jig – Worked well.
Then got this results
Then made up the aprons and using the Jessem Doweling jig
then a dry fit
More to come…..
-- Rob V
View tenontim's profile
tenontim
2131 posts in 3984 days
#6 posted 06-15-2012 11:44 AM
Rob, if I might make a suggestion. You should make some diagonal braces, that go from on apron to the other, for the corners. Glue and screw them to the aprons. Make a flat area at the top of each leg for the brace to mate with, and put a lag screw through the brace into the leg. I think the dowel joints are going to give you grief later, if you don’t strengthen the up, since there is no other support for the legs. Photo below is larger, rougher, version of what I’m talking about.
Rob Vicelli
#7 posted 06-15-2012 12:47 PM
TenonTim: Thanks for the tip, I neglected to say that I have some metal ones I purchase from Rockler that are not installed yet, Though I like the idea of the wood ones- Thought I would put them in when the top was drying.
-- Rob V
