Makita 1806B 6-3/4" Power Planer - Blades?
Forum topic by Doss posted 06-12-2012 09:47 PM 5525 views 0 times favorited 6 replies Add to Favorites Watch
View Doss's profile
Doss
779 posts in 2229 days
06-12-2012 09:47 PM
Topic tags/keywords: makita 1806b 6-34 675 power planer planer knives blades knife carbide question
As the owner of this monster power planer, I’m faced with a problem… where to source a carbide knife set for this beast?
I tried Global tooling, but they didn’t have anything for me. Anyone have any suggestions?
Also, how do you know if the tools you’re using are not normal? They come in wooden crates:
-- "Well, at least we can still use it as firewood... maybe." - Doss
10260 posts in 3612 days
#1 posted 06-12-2012 10:17 PM
You can get them in carbide for the 155mm planers and jointers
by Makita, but a Google search for 170mm makes it look like
perhaps they aren’t made. If the part is made, it has a Makita
part number. Knowing that number will get you closer.
View Doss's profile
Doss
#2 posted 06-13-2012 04:00 PM
Yeah, I have the Makita part number for the HSS knives:
7931864 or 793186-4
They just come in high-speed steel (HSS). I was hoping someone would know how to source some carbide-tipped ones.
Maybe I can have a machine shop make a cutterhead for a helix-type knife set. Sounds like I have some fabrication work ahead of me… maybe this will be reason enough to buy a small CNC mill. HA!
#3 posted 06-13-2012 06:15 PM
You might sell the 1806 and get an 1805.
I’ve had both an 1805 and and Ryobi which is very similar
and takes the same blades. Hitachi probably made a 155mm
format planer. I suspect Makita introduced the 170mm
planer because their patents on the 155mm format planers
expired and the Chinese started making them willy nilly.
View Doss's profile
Doss
#4 posted 06-13-2012 06:37 PM
It’s a nice thought, but I like the 1806. I’d much rather spend my money on more HSS knives than buying an 1805 to replace my 1806.
I know Byrd makes shelix head for a 6” Makita jointer. I wonder what they’d charge to extend that or cut down an 8” to fit the 1806.
#5 posted 06-13-2012 06:43 PM
The carbide blades for Makita format jointers and hand
planers are machined from solid tungsten carbide. A
local saw shop may be able to to it for you as it’s not
that different from making a moulder knife. Expect
sticker shock.
View 303Woodwork's profile
303Woodwork
25 posts in 2478 days
#6 posted 06-20-2012 07:32 AM
The Makita 1806B certainly is a beast!
-- Gotta love woodworking!
