Box joints....finally
Forum topic by D_Allen posted 06-12-2012 01:20 AM 1141 views 0 times favorited 7 replies Add to Favorites Watch
View D_Allen's profile
D_Allen
495 posts in 3019 days
06-12-2012 01:20 AM
Well, I think I have this figured out.
This is my first full thickness test piece. Lots of tweaking.
Actually, these were cut to half the thickness first and then the full thickness.
Some of the cuts show a step where something was not quite seated I guess.
With a little more practice, this may begin to look good.
Used a shop made router jig that slides on a drawer slide.
-- Website is finally up and running....www.woodandwrite.com
7 replies so far
View lab7654's profile
lab7654
266 posts in 2482 days
#1 posted 06-12-2012 01:25 AM
Looks great! Dry fit I presume? I imagine it would look beautiful glued up and with a bit of planing/sanding.
-- Tristin King -- When in doubt, sand it.
D_Allen
#2 posted 06-12-2012 01:49 AM
Yeh, dry fit. Just some 3/4 poplar for testing. It needs about a 32nd more in depth.
But, now I need to make up some stock for sides of some display cases so I guess I need to finish the crosscut sled. So much to do! Thanks for the look and complement.
View tyskkvinna's profile
tyskkvinna
1310 posts in 3221 days
#3 posted 06-12-2012 02:06 AM
ooh hey looks great. I fought with box joints quite a bit and will probably come back to it later.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Bsmith's profile
Bsmith
330 posts in 2905 days
#4 posted 06-12-2012 02:38 AM
I think once you sand them down you should be very happy with them. Good job!
-- Bryan
View lew's profile
lew
12495 posts in 3990 days
#5 posted 06-12-2012 03:18 PM
Nice!
People say these are simple to do, I’ve never found that to be the case.
View helluvawreck's profile
helluvawreck
32086 posts in 3102 days
#6 posted 06-12-2012 03:38 PM
I’ve been making boxes consistently for a couple of months now using mitered corners with keys. Box joints is something that I haven’t tried yet but am looking forward to it. I still have to make my jig. I hope that my first ones turn out this well. Congratulations. You seem to be getting the bugs out so we’ll be looking forward to seeing some of your boxes with box joints.
helluvawreck
https://woodworkingexpo.wordpress.com
D_Allen
#7 posted 06-12-2012 09:52 PM
It’s one of those techniques where you can make a box joint that is good enough for say some workbench drawers and then there are the ones that are for show boxes. The most important issue is to get the spaces to be exactly the same size as the slots. I don’t mean close. Close is what the ones showing are above. I will need to make a few more final adjustments when I make the box sides. You see, if there is a .002” difference, it gets added on each pass and depending on the width of the boards, you are looking at a lot of difference. That is why using a dovetail jig is much more accurate. It is a machined template and is more precise. I actually was making several adjustments to mine in the range of .002” to .01” to get this close. You also need to be sure the sawdust is removed from the guide pin area each time and be sure the ends are square and seated on the jig properly. There are a lot of things that can effect the cuts and one bad cut can ruin a piece of stock.
