WHy is my router just stopping on me?
Forum topic by Milo posted 06-11-2012 08:50 PM 1730 views 0 times favorited 20 replies Add to Favorites Watch
View Milo's profile
Milo
869 posts in 3462 days
06-11-2012 08:50 PM
Topic tags/keywords: router question
I’ve got a Ryobi R130 router I have dedicated for use ona horizontal router table. Today the stupid thing just quit, mid run. It will fire up briefly when I hit the trigger after sitting a bit, but won’t run continuously.
Is it overheating? Brushes? Can someone please help me out?
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
20 replies so far
View Ted's profile
Ted
2873 posts in 2354 days
#1 posted 06-11-2012 09:05 PM
I’ve had that happen with various tools and turned out to be dust inside the trigger housing breaking the contact. I had to drill out the rivets holding it together to get it open, and use tiny screws and nuts to put it back together. My Ryobi belt sander does this about once a year, and I have that trigger taped together. Whatever works, ya know. I bet it’s the trigger.
-- You can collect dust or you can make dust. I choose to make it.
View Milo's profile
Milo
#2 posted 06-11-2012 09:19 PM
I think I can take that trigger apart. Thanks Ted!
View devann's profile
devann
2246 posts in 2836 days
#3 posted 06-11-2012 09:21 PM
I had a similar problem with a miter saw I had and it turned out to be a broken brush holder.
View Ted's profile
Ted
#4 posted 06-11-2012 09:21 PM
Of course you can, just make sure to unplug the tool first… LOL!
Note that Darrell might be right too. May as well take a look at those brushes and holders before you take the trigger apart.
View RussellAP's profile
RussellAP
3104 posts in 2430 days
#5 posted 06-11-2012 09:21 PM
When you get it apart, try a little RTV or silicone to keep the dust out.
View Joe Lyddon's profile
Joe Lyddon
10265 posts in 4196 days
#6 posted 06-11-2012 09:44 PM
I’m with TedW…
Might not hurt to Blow it out good with an air hose… just for kicks… to see if makes a difference… LOL
View Tokolosi's profile
Tokolosi
678 posts in 2498 days
#7 posted 06-11-2012 10:07 PM
Had a similiar problem with my previous table saw. Dust in the switch housing was the culprit as well. It was when it started smoking from the switch one day when I discovered the propblem. Untill then I just thought I had a picky saw. The wood dust caught fire. Luckily it was packed in so tight which kept it to a slow smolder.
-- “There is nothing like looking, if you want to find something. You certainly usually find something, if you look, but it is not always quite the something you were after.” ~ JRR Tolkien
View TrBlu's profile
TrBlu
386 posts in 2769 days
#8 posted 06-11-2012 10:26 PM
Could also be dust or corrossion causing the brushes to loose contact.
-- The more I work with wood the more I recognize only God can make something as beautiful as a tree. I hope my humble attempts at this craft do justice by His masterpiece. -- Tim
View Milo's profile
Milo
#9 posted 06-11-2012 10:35 PM
The trigger looked fine. There was hardly anything in the housing at all.
I’m going to check the brushes. I noticed the slight smell of ozone in the air when I walked back into the shop.
This Ryobi really is a hunk of junk. Glad I have it for this purpose, but if I was using it for an all round router, I’d go nuts!
THANKS everyone! If I can figure out how to get to the brushes in this thing, I’ll let you know.
View MrUnix's profile
MrUnix
6926 posts in 2342 days
#10 posted 06-11-2012 10:37 PM
If it is fairly new, take it back and get another one! Otherwise, I’m with everyone else and you got a loose/failing connection somewhere. It could be just about anything, so you really need to take it apart, clean it up and inspect. A cheap meter will also help trace down any shorts/breaks. Intermittent problems like that can be a pain.. particularly those that are thermal related (only happens when the thing gets hot).
View Remedyman's profile
Remedyman
47 posts in 2340 days
#11 posted 06-11-2012 10:50 PM
I think the heat might be a big clue. I would try to things.
First, if it stops working tap on pieces of it with the trigger on (but mounted safely) with the plastic handle of screw driver. If at any point it kicks on, you probably have a loose connection in that area.
If nothing happens, then try blowing inside the case with a can of compressed air held upside down. You will QUICKLY reduce the temperature of anything that you blow it on. And that will help you figure out if it is a heat issue.
Hopefully these two tips will help you figure it out without getting too far into it.
-- As long as our customers are happy, we have done a good job. Even if we are our own customer.
Joe Lyddon
#12 posted 06-11-2012 10:57 PM
Milo,
Did you blow it out like I suggested?
View dhazelton's profile
dhazelton
2789 posts in 2440 days
#13 posted 06-11-2012 11:55 PM
Get some CRC Electrical Switch/Motor cleaner and shoot it liberally in to the switch, then tip the router so any liquid runs out. Could just be oxidation on the contacts. You can get it at an auto parts store, or get electircal switch cleaner at a Radio Shack if closer.
View roundguy's profile
roundguy
62 posts in 2828 days
#14 posted 06-12-2012 04:08 AM
Try bypassing the switch (safely) and see if it stays running.
View Milo's profile
Milo
#15 posted 06-12-2012 01:11 PM
Took the router apart today. Surprisingly little dust inside the unit and switch handle.
I blew everything out and checked for shorts. The ONLY thing I found was one of the brushes had popped out of place. The brushes were in a housing and fit into a slot in the router. Now, it could have come out when I removed the housing, I don’t know.
Joe, I did blow out everything!
dhazelton – I will try that today.
roundguy – how would I do that?
