A really stupid question about 110v transformers
Forum topic by 404 - Not Found posted 06-11-2012 07:46 PM 3858 views 0 times favorited 4 replies Add to Favorites Watch
404 - Not Found
2544 posts in 3207 days
06-11-2012 07:46 PM
This bit is for the benefit of LJ’s across the Atlantic – in England and Ireland we’re on 230/240V mains. If you are working on a building site, power is stepped down to 110v for Health & Safety reasons using a transformer.
Now to the dumb question, why is there a reset button on a 110v transformer and what is it for?
Is the reset button supposed to be pressed when you’re plugging it in?
I asked the guy in the hardware store and he didn’t know.
I’m not losing sleep over this vexing issue, but if anyone can enlighten me I would be grateful.
View knotscott's profile
knotscott
8178 posts in 3613 days
#1 posted 06-11-2012 07:53 PM
I’m no electrician, so I can only guess, but stepping down the voltage to 110v should also double the amperage draw, so it’s very feasible that quite a bit of amperage could flow through the transformer….thus a circuit breaker with a reset button for protection from overload.
View Mosquito's profile
Mosquito
9566 posts in 2530 days
#2 posted 06-11-2012 07:54 PM
That was my guess too Scott
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#3 posted 06-11-2012 07:54 PM
And you use 50hz instead of 60hz :) As for the reset button, only thing I can imagine is that the thing has an internal circuit breaker for protection, and that button is to reset it when it gets tripped.
View Scot's profile
Scot
344 posts in 3634 days
#4 posted 06-11-2012 08:59 PM
Knotscott is correct. A CB is installed because of the change in amperage.
When voltage goes up amperage goes down, when voltage goes down amperage goes up.
Even though you may have a CB feeding a transformer (primary side), the secondary side needs to have its own over current protection.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
