Buying router and have silly question.
Forum topic by WOODIE1 posted 06-11-2012 07:07 AM 997 views 0 times favorited 5 replies Add to Favorites Watch
View WOODIE1's profile
WOODIE1
117 posts in 2273 days
06-11-2012 07:07 AM
Not sure how I made it so far without one but I need a router. I was looking at the new Bosch but have a question….
If you can lock the plunge on a plunge why do I need a fixed base router?? They all sell in kits but I know I will need more then one say for trim or dedicated table so what is the need for the 2 set ups???
I am looking to do some cabinet doors with shaker style rail/stiles and flat panels. I do not have a table yet.
Thanks
5 replies so far
View devann's profile
devann
2246 posts in 2686 days
#1 posted 06-11-2012 07:21 AM
First, the screw base is easier to adjust.
When my last router died I purchased one of those kits with the motor and two bases, one plunge and one screw. I mounted the screw base to my router table and after a couple times of removing and replacing it I purchased another router with a screw base.
Turns out it was one of the best tool buying decisions I ever made. I now have two identical motors & three bases. Sometime in the future you’re gonna want to leave the router table setup as is and need a hand held at the same time. Sure makes life easier.
View 12strings's profile
12strings
434 posts in 2378 days
#2 posted 06-11-2012 08:48 AM
Well, I also got one of the combo kits, (Milwaukee), and generally dedicate the non-plunge base to my router table…I rarely do any router work that is not at the router table, but if I do, I use the plunge base…whether I’m plunging or not. So for me, having 2 bases is convenient.
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
View knotscott's profile
knotscott
8006 posts in 3369 days
#3 posted 06-11-2012 09:12 AM
Fixed bases tend to have less slop and a lower center of gravity.
View canadianchips's profile
canadianchips
2600 posts in 2991 days
#4 posted 06-11-2012 11:17 AM
Kits are okay…....I have 18 routers, only one has plunge….I rarely use the plunge. I would buy as large as possible motor you can if you are planning on using it for panels. Spend extra dollars on motor size vs. two bases.
View kizerpea's profile
kizerpea
774 posts in 2361 days
#5 posted 06-11-2012 11:53 AM
Yeah me to …dont use the plumge much…use fixed for router table for fine adjustment bosch 1617 evs
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
