How to remove dried paint from clothes?
Forum topic by blackthumb posted 55 days ago 516 views 0 times favorited 12 replies Add to Favorites
View blackthumb's profile
blackthumb
16 posts in 140 days
55 days ago
Does anybody know how I can remove dried paint from clothes, any websites, products or anything?
View Mark Shymanski's profile
Mark Shymanski
389 posts in 155 days
55 days ago
Scissors:-) ?
-- ....next big purchase is wood for the next project, Mark
View Betsy's profile
Betsy
1760 posts in 338 days
55 days ago
it’s pretty hard to remove dried paint because it has generally absorbed into the interior fibers of the material. With that said, you can try a little bit of whatever solvent the paint says to use to remove it as if it was wet. I’ve also had limited luck using rubbing alcohol on latex paint. But limited success is the best I’ve done. Generally anything that I’ve got paint on has just become my favorite clothes to do future painting in.
-- Betsy - GO BUCKS!
View tenontim's profile
tenontim
828 posts in 187 days
54 days ago
Go to Wal Mart and buy another shirt, pants, whatever, before the laundry person see it.
-- Tim -- http://tmuli.com
View lew's profile
lew
901 posts in 198 days
54 days ago
View SteveB's profile
SteveB
19 posts in 500 days
54 days ago
I use Goof Off to remove dried latex paint. It works pretty well on oil-based paint, too. I’ve used it get paint out of carpet.
  • Test the solvent in a hidden area to make sure it doesn’t damage the carpet.
  • Flood the paint drop with the solvent. Be generous.
  • Scrub with a paper towel or old rag.
  • Suck up the mess with a shop vacuum.
  • Repeat until the paint is gone.
If you’re going to do more than just a small job, buy xylene instead—it’s cheaper. Goof Off is mostly xylene.
-- Steve B - New Life Home Improvement
View Earle Wright's profile
Earle Wright
122 posts in 163 days
54 days ago
Generally 40 grit or larger on a side grinder will obliterate whatever paint you’re lookin’ at.
-- Earle Wright, Lenoir City, Tennessee
View steveosshop's profile
steveosshop
178 posts in 68 days
54 days ago
Sometimes the citrus style hand cleaners will take the paint stains off. I have had luck with a couple brands for removing all kinds of stains from clothing, but a word of warning, it will sometimes remove the die in clothing too.
-- Steve-o
View dsb1829's profile
dsb1829
69 posts in 70 days
53 days ago
I don’t, it adds character ;-)
-- Doug, woodworking in Alabama
View kwhit190211's profile
kwhit190211
12 posts in 198 days
41 days ago
Now you have a pair of work clothes to use on your next project. Once paint is dried that’s it!
View moshel's profile
moshel
125 posts in 126 days
41 days ago
if the cloth was white, chlorine based liquids can work, like chlorex. they dont really remove the paint but remove the pigment. oil based paint can be removed with chaotic soda (drain opener or paint stripper, drain opener is cheaper), but it will happily digest any organic material, like your skin or cotton based cloth, so it is good only for 100% synthetic fabrics.
-- The woods are lovely, dark and deep, but I have promises to keep...
View brianinpa's profile
brianinpa
514 posts in 165 days
40 days ago
I just keep wearing that article of clothing everytime I paint. This way I never have to worry about removing paint from another article of clothing.
View Tom Adamski's profile
Tom Adamski
213 posts in 213 days
40 days ago
I’ll second SteveB… Goofoff is the best… Just don’t use it in the house! The smell will drive you nuts for hours. Treat the paint and let it soak in. Blot out as much as you can and then rinse it out. (Outside of course) Then take it inside and wash it as normal. Check it before you put it in the dryer, as heat will set any paint you missed.
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
Bookmark And Share This Page
