Which Jointer would you buy?
Forum topic by RussellAP posted 06-11-2012 01:54 AM 11193 views 0 times favorited 31 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2251 days
06-11-2012 01:54 AM
I can get this at Lowes for $375.
12-Blade 115-Volt Bench Jointer
Patented Helical Head: Helical cutterhead has indexable carbide inserts for a superior finish, longer cut time, and quieter operation
Motor: 12 amp, 115v, 60Hz
Speed: 12000 RPM
Cutting capacity: width: 6 1/8”, depth: 1/8”
Number of knives: 12 two-sided high speed steel inserts
Cast iron work top and aluminum fence
I can get this at Lowes for $250
2-Blade 120-Volt Bench Jointer
Variable speed range of 6000 to 11000 RPM allows the user to select the right speed for the size and hardness of material being cut
Two-knife cutter head with jackscrew knife leveling arrangement allows for easy replacement and adjustment of knives
Built-in cutter head lock facilitates knife replacement and adjustment
Center mounted fence gives needed support throughout the cut for accurate edge jointing
This is on sale for $175 at HF
Make fast, clean rabbet cuts up to 3/8”
Versatile jointer features cast iron fence assembly with positive stops at 45° and 176°
and 90° and 176°
Infeed and outfeed tables adjust by rack and pinion controls
Precision ground steel knives
Motor: 1 HP, 110V, 8 amp
Infeed table size: 22-1/2”
Outfeed table size: 19-1/2”
Overall table length: 42-1/2”
Cutterhead speed: 4600 RPM
Cutterhead size: 3”
Max depth of cut: 3/8”
Shipping Weight: 179.92 lb.
I’m partial to the HF model but I like the higher speeds of the other two. I have a $500 credit at Lowes too.
31 replies so far
View Bobmedic's profile
Bobmedic
379 posts in 2766 days
#1 posted 06-11-2012 02:03 AM
I looked at those when I was in the market for a jointer. There are many people that have mixed opinions about the helical cutters and the granite tables. I read several bad reviews so I opted for a used Jet on craigslist.
View DMC1903's profile
DMC1903
285 posts in 2291 days
#2 posted 06-11-2012 03:17 AM
I purchased that Steel City Jointer from Lowes several months ago. It was a special order item, when the box arrived it was destroyed and parts were missing ( thanks UPS)
So, after contacting Steel City, getting the missing parts, I was ready to make some chips.
At first the Jointer gave a butter smooth cut, then it began to go out of co-planer. After several festering minutes it was perfectly co-plane, several board ft latter….out of co-plane. This cycle happened 4-5 times, the reason was the how the in-feed and out-feed tables are secured to the unit. There are 4 set screws that adjust the plane,wth an attachment bolt that screws into the set screws.
I returned the unit to Lowes and purchased a 8’ grizzly jointer, It was my last pc of equipment from Steel City
On a good note, the Helical cutter head is amazing!!!!
Good Luck
View ShaneA's profile
ShaneA
6909 posts in 2563 days
#3 posted 06-11-2012 03:26 AM
Russell, of those…the full size one is far better. I have a delta benchtop somewhere in my basement. Good for small projects. When I upgraded to the ridgid 6” model it was HUGE step up. I know where you can get a good deal on a gently used delta : )
View Jim Jakosh's profile (online now)
Jim Jakosh
20283 posts in 3070 days
#4 posted 06-11-2012 03:38 AM
I would take into consideration the length of the table. Some of them looked pretty short.
I bought a Grizzly 6” 1 1/2 hp with a standard cutter head and it is 46” long and I love it. It has the switch up high and the fence tilts either way. Knives are not hard to change and it has parallelogram tables.
Look at the Grizzly model G0452. It is up to $550 in the new catalog- page 37. It is solid cast iron table and fence. The helical head model is $750.
The 1 hp model G0654 is $425. Both are 3 cutter heads. Nice machines.
That Steel city one with 6” width and helical head sounds pretty cheap. I have heard that with a helical head, you cannot take off very small amounts with it, but I have never had one
I don’t see an out feed table adjustment on the porter cable and steel city machines. That is very important to set it up right after changing blades.
View rockindavan's profile
rockindavan
299 posts in 2600 days
#5 posted 06-11-2012 03:41 AM
I have used a small benchtop planer and they are far too light to do a good job. In this situation I would reluctantly suggest the HF option…it could be a HF gem..you never know
RussellAP
#6 posted 06-11-2012 03:43 AM
Shane, Sure, what do you have?
ShaneA
#7 posted 06-11-2012 04:03 AM
I have the delta benchtop unit. Looks exactly like the PC pictured above. The table length is the drawback. Its about 3 or 4 yrs old, about 30-40 bf total on it. Been in the basement for at least 2 1/2 yrs.
RussellAP
#8 posted 06-11-2012 04:13 AM
Shane, now I’m leaning toward this one.
Grizzly G0654 6” x 46” Jointer
View waho6o9's profile
waho6o9
8164 posts in 2541 days
#9 posted 06-11-2012 04:16 AM
Sure is a nice Grizzly Russell, it well serve you well for years.
RussellAP
#10 posted 06-11-2012 04:20 AM
I’m mostly going to use it for WRC. Hand planing works, but when you make as many Adirondack chairs as I do, you need something that will make it smooth quickly.
View NormG's profile
NormG
5931 posts in 2968 days
#11 posted 06-11-2012 04:34 AM
Grizz, if not then the HF
-- Norman - I never never make a mistake, I just change the design.
RussellAP
#12 posted 06-11-2012 04:35 AM
Shane, show me some pictures.
View dpop24's profile
dpop24
115 posts in 2534 days
#13 posted 06-11-2012 06:51 AM
For the same money, you can step up quite a bit in size and quality by going used on Craigslist. I picked up a 6” Jet for $275 last year and with just a bit of maintenance and time to set it up correctly, it’s an outstanding machine. Any of a number of machines (Jet, Ridgid, Grizzly) in this category would serve you well for many years to come.
-- If it ain't broke, take it apart and find out why
View ShipWreck's profile
ShipWreck
557 posts in 3717 days
#14 posted 06-11-2012 09:53 AM
Russ, the two bench top models are pretty good machines but I think they are way too small for the Adirondack chair business. I have used the HF dozens of times over the past 5-6 years and can say that it is the best value for the money from the machines you have posted. The Grizzly is almost a exact copy of the Craftsman 6” jointer series but with a different paint job. The fence system on these models suck! The fence on the HF is a bit twitchy also but a hell of alot simpler to set than the Grizz.
I think the HF is a very underrated machine.
V/R….John
View knotscott's profile
knotscott
7980 posts in 3340 days
#15 posted 06-11-2012 09:58 AM
If price is the driving factor, without question get the stationary model. The capacity, mass, and stability will give it the upper hand in performance. It also has a belt drive induction motor vs a direct drive universal motor.
showing 1 through 15 of 31 replies
