Can Mahogany Be Safely Burnt In Fireplace?
Forum topic by ShaneA posted 06-11-2012 01:38 AM 11041 views 0 times favorited 5 replies Add to Favorites Watch
View ShaneA's profile
ShaneA
6890 posts in 2507 days
06-11-2012 01:38 AM
Topic tags/keywords: mahogany african mohagany burning wood
I have been using african mahogany on my most recent project. Starting to accumulate lots of little pieces. Usually I give all most too small to use off cuts to my mom, to burn in her woodburning fireplace. However, I have always given her domestics. Just pitched other more exotic offcuts. Since there will be quite a bit, I would hate to see it go to waste. So, does anyone know if it is ok to burn mahagony without any fumes or other crazy circumstances that would make it a bad idea. Thanks as always.
5 replies so far
View lysdexic's profile
lysdexic
5250 posts in 2532 days
#1 posted 06-11-2012 04:25 PM
Shane I don’t know the answer to this but I’m following along. I’m interested to see what response you get.
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
View Loren's profile
9981 posts in 3557 days
#2 posted 06-11-2012 05:01 PM
Yes, Khaya is safe to burn. She may be allergic to the dust
but if the pieces are clean I would not expect problems.
ShaneA
#3 posted 06-11-2012 05:26 PM
May be a tough one to answer. I guess if there is doubt I may just pitch it. Especially the real small stuff.
Edit: thanks loren, I had typed that up and forget to post it, the posted before I saw your response.
View Bearpie's profile
Bearpie
2601 posts in 2927 days
#4 posted 06-11-2012 07:15 PM
The biggest factor is that you have a good updraft in the fireplace to keep smoke from coming back into the room. If you have that, you can burn most anything except toxic woods and things.
-- Erwin, Jacksonville, FL
View Dan's profile
Dan
3630 posts in 2789 days
#5 posted 06-11-2012 08:13 PM
I burned a bunch of Mahogany in my wood stove not knowing it was Mahogany. I am still kicking myself for that. I am still alive and well, my kids are fine so I would say its safe to burn.
-- Dan - "Collector of Hand Planes"
