Mild rust on bandsaw table.
Forum topic by Ryan Haasen posted 06-11-2012 01:02 AM 1300 views 0 times favorited 7 replies Add to Favorites Watch
View Ryan Haasen's profile
Ryan Haasen
385 posts in 2635 days
06-11-2012 01:02 AM
Topic tags/keywords: rust bandsaw table mild remove
As you can see, I have some very mild rust on my bandsaw table, there are a few more spots which are not visible in the picture. I was wondering if it is worth removing. I want my bandsaw to look as nice as possible without any rust, but I don’t want to scratch it up trying to remove it. What would you guys do? If I were to remove it, what would be the best way without scratching it up?
Thanks a lot, your input is appreciated,
Ryan
-- Ryan
7 replies so far
View David Kirtley's profile
David Kirtley
1286 posts in 3232 days
#1 posted 06-11-2012 01:29 AM
Short answer: Scotchbrite pad or fine steel wool
Now that that’s out of the way… Yikes, mine doesn’t look that good at it’s best.
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#2 posted 06-11-2012 01:49 AM
The rust color doesn’t bother me but the surface needs to be smooth and slick. I second the Scotchbrite or sttel wool but would apply paste wax at the same time using the SB or steel wool. Then periodically redo the wax.
Ryan Haasen
#3 posted 06-11-2012 01:53 AM
Thanks for your help guys! I will give it a try!
-- Ryan
View Jim Jakosh's profile
Jim Jakosh
21953 posts in 3339 days
#4 posted 06-11-2012 03:19 AM
Steel wool and then wax the table!
View Ken Dolph's profile
Ken Dolph
15 posts in 3396 days
#5 posted 06-12-2012 12:41 PM
If you are worried about scratching the top, here is a fascinating fact:
Rub it with aluminum foil. The aluminum will remove the oxygen from the rust. I was very surprised when I first tried this.
-- Ken Dolph, Corian Master http://sites.google.com/site/coriartinc/
View tyskkvinna's profile
tyskkvinna
1310 posts in 3220 days
#6 posted 06-12-2012 12:47 PM
Scotchbrite now makes “no abrasion” pads (they are neon blue)—they have become standard use in my shop! Not great if you have heavy grit or rust but if you are doing it for maintenance… fantastic. buffs the paste wax out really nice too.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
Ryan Haasen
#7 posted 06-12-2012 01:12 PM
Those are great idea’s, I’ll try both of them out and see what happens!
-- Ryan
