Question on metal lathe tool
Forum topic by D_Allen posted 06-10-2012 07:34 PM 1442 views 0 times favorited 11 replies Add to Favorites Watch
View D_Allen's profile
D_Allen
495 posts in 2747 days
06-10-2012 07:34 PM
Hopefully there are some folks here with experience with these things.
I got a freebee boring bar this weekend as part of a package deal.
It is a Valenite 1/2” x 6” with a place for a carbide insert. My hope is to find some inserts to use this when turning small pieces of brass and aluminum. However, I cannot figure out for sure which inserts it takes.
The model # is S06M-SCFPR-2 Other info stamped on it is 1T3-H PT-589T and CP-21.5
I think maybe 2 numbers that will fit ar CPGT 21.51 and CPMW 21.51….but I’m not sure.
Anyone out there know about these? Thanks.
-- Website is finally up and running....www.woodandwrite.com
11 replies so far
View lew's profile
lew
12017 posts in 3718 days
#1 posted 06-10-2012 07:39 PM
http://www.dermu.com/allegati%5CGreenleaf0304.pdf
http://www.pts-tools.com/Catalog_pdf/PTSTOOLS/PTS2011CATALOG/J0338.pdf
Not sure if this will help but may give you a start.
D_Allen
#2 posted 06-10-2012 10:31 PM
Thank you Lew.
The link to PTS was most helpful.
I’ll give them a call and see if they can tell me if the one I found will work with the bar I have.
View MrRon's profile
MrRon
4710 posts in 3206 days
#3 posted 06-11-2012 04:04 PM
Check around in different catalogs. Some companies sell only in packs of 10 which can be costly. A place like Wholesale Tool sells them individually.
View Ruaidhri's profile
Ruaidhri
3 posts in 2139 days
#4 posted 06-12-2012 11:40 PM
For brass and aluminium I wouldn’t bother – have a go at making a tip up from a piece of scrap steel. A couple of minutes on the grinder and the right size hole and you’ll have all you want :-)
Properly tempered and honed you should be able to get a superb finish straight from the tool, and a better cutting edge than from carbide. You can also have one with no rake for the brass, and another with a suitable rake for aluminium.
RuaidhrĂ­
-- RuaidhrĂ­, Dublin, Ireland
View tyskkvinna's profile
tyskkvinna
1310 posts in 2949 days
#5 posted 06-13-2012 01:20 AM
I agree that for brass and aluminum I wouldn’t bother with carbide, unless you intend to use it pretty often. I make my own inserts for wood all the time (my lathe is a metal lathe) and I do as Ruaidhri suggests. Works really well!
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
D_Allen
#6 posted 06-16-2012 09:51 PM
Well, I’m no machinist by any means but this is the best cut I have been able to do on brass.
My woodworking tools would chatter and leave ridges. This thing works good and I haven’t even made a handle for it yet.
I made an educated guess about what insert would work and this one fit perfectly.
However, it does not do that well on plastic and wood. The inserts used in the woodworking tools must be decidedly different.
tyskkvinna
#7 posted 06-16-2012 11:50 PM
If it does a good job on brass, it’s going to do a horrible job on plastic and worse on wood.
The wood inserts come to a sharp centre point and usually have more carbide.
D_Allen
#8 posted 06-17-2012 01:31 AM
Thanks Lis, that’s good info.
Since this boring bar was free and the insert cost me about $12, it was worth the risk.
If it does this well on aluminum then I’m all set. It is what I wanted to use it for to begin with.
View Planeman40's profile
Planeman40
1150 posts in 2724 days
#9 posted 06-17-2012 04:14 AM
The truth is those carbide inserts are designed for production machining of steel and very hard to turn alloys where carefully calculated speeds and lots of lubricant is used. Surprisingly, the machining of steel doesn’t require a razor sharp edge like wood and soft metals, thus most inserts are made to the sharpness required which is usually not sharp enough for wood. I guess you could sit down and sharpen a carbide insert, but then that defeats the purpose of having a throw-away insert and you might as well just have a good steel turning tool.
Planeman
View tomd's profile
tomd
2148 posts in 3733 days
#10 posted 06-17-2012 04:33 AM
When maching brass or aluminium, carbide is not even needed. I purchase small square pieces of HSS which are about 3 inches long and come 1/4, 5/16, 3/8 and 1/2 inch square from Enco for less than a dollar each. Just grind a tip of any style you desire and you can sharpen both ends. HSS does an excellent job on steel, brass, aluminium and wood. Good wood turning tools use HSS and you can get a very sharp edge on HSS. When it dulls just go back to the grinder for a minute and you ready to go again.
-- Tom D
D_Allen
#11 posted 06-24-2012 07:38 PM
Well, I finally made a handle. It is oak with an aluminum ferrule. The blank I used was not large enough to end up wider than the ferrule. But it will do.
