Forum topic by Woodworker_Collins | posted 06-10-2012 05:03 PM | 1325 views | 0 times favorited | 3 replies | ![]() |
Topic tags/keywords: tip resource question mahogany finishing refurbishing sanding modern polyurethane lacquer brushing I am nearly to the finishing stage of a restoration project i have been doing on an old mahogany table, i am going for a semi gloss finish but i want it to be as easy as possible to apply so i wonder in your opinion which is easier to apply. By this i mean is it easy to spread, do you have to sad between coats, how may coats do you need to put on and which drys quicker. I thank all who try to help me with this problem. -- Adam, Ireland, http://www.youtube.com/user/AdamTheWoodworker |
3 replies so far
#1 posted 06-10-2012 05:10 PM |
I have found they both dry in about the same amount of time. I use 0000 steel wool between coats. The polyurethane is definitely easier to spread than lacquer. You will find the fumes on the lacquer and oil based poly strong to work with. You can also buy water based poly which has no fumes. Good luck…............... -- mike............... |
#2 posted 06-10-2012 05:22 PM |
Lacquer dries really fast so dust in the finish isn’t as much If you want the toughest finish for the stuff you choose, |
#3 posted 06-10-2012 09:17 PM |
Good advice from Loren. Pesonally, I would choose polyurethane for a table because it is more durable and resists water and alcohol stains better. I always sand lightly between coats with 240 grit to remove dust nibs and hair straws. I usually do three coats. I like to rub out the final coat with car rubbing compound you can buy at a petrol station. this leaves a super smooth finish which is beautiful and very nice to the touch. My advice is to go for better rather than easier when it comes to tables. -- Mike, an American living in Norway. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4903 |
6694 |
28051 |
CNC Woodworking
211 |
Hand Tools
5406 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
