Veneer Press doubles as food saver?
Forum topic by Scotty Stepp posted 06-10-2012 12:36 PM 1543 views 0 times favorited 3 replies Add to Favorites Watch
View Scotty Stepp's profile
Scotty Stepp
25 posts in 3588 days
06-10-2012 12:36 PM
I recently put together a vacuum press from JoeWoodworker.com and was thinking it could be used as a food saver vacuum as well. My vacuum is the venturi model which hooks up to my air compressor. My primary concern is the moisture that will be getting sucked out of the bag and into my vacuum unit. Any ideas on how to avoid moisture problems? I contacted Joe and he didn’t know of any kind of filter but guessed there was one out there somewhere.
Thanks.
3 replies so far
View Gene Howe's profile
Gene Howe
10535 posts in 3454 days
#1 posted 06-10-2012 12:40 PM
For food, you don’t need continuous vacuum over a long time. I’d think a decent wet/dry shop vac would work.
Scotty Stepp
#2 posted 06-10-2012 01:04 PM
Thanks Gene. I saw the wet/dry vac as an option but I would like to put a bit more vacuum pressure into each bag and have an option that is easier and quieter to use in the kitchen.
View poopiekat's profile
poopiekat
4356 posts in 3760 days
#3 posted 06-10-2012 04:10 PM
Hmmm, I was thinking just the opposite, using a food saver as a veneer press!!
