Plywood Shelf Support - Cover Exposed Edge of Plywood
Forum topic by avxflyer posted 06-09-2012 08:21 PM 4298 views 0 times favorited 13 replies Add to Favorites Watch
View avxflyer's profile
avxflyer
3 posts in 2229 days
06-09-2012 08:21 PM
Topic tags/keywords: plywood sag sag support face board
Hi Guys,
I’m installing some shelves into an entertainment niche in my house. It’s an opening about 8 feet high and 4 feet wide. I’m using 3/4×1-1/2 birch to support the shelf on 3 sides. The actual shelf is 3/4” birch plywood. I want to hide the exposed edge of the plywood and the cleats so want to attach a piece of 3/4×3 birch to the exposed edge of the plywood and also want this to support the weight of the shelf since the span is 47”. What is the best way to attach the board to the edge of the plywood? I was thinking of using dowels, but maybe just Gorilla Glue is sufficient. Any tips? I don’t want to have screws or nail holes along the exposed wood.
13 replies so far
View devann's profile
devann
2246 posts in 2744 days
#1 posted 06-09-2012 08:28 PM
I like using biscuts for applications like that. Instead of a biscut you could also use a spline.
View felkadelic's profile
felkadelic
218 posts in 2592 days
#2 posted 06-09-2012 08:34 PM
Biscuits are probably what I’d use, but you could also use pocket screws depending on how visible they’d be (I’m having a hard time envisioning your project in my head)
View Lifesaver2000's profile
Lifesaver2000
555 posts in 3164 days
#3 posted 06-09-2012 08:58 PM
If I understand correctly, the solid wood board will be at a right angle to the plywood, flush at the top and then projecting down a couple inches below the ply to hide the cleats.
In similar situations I have created a 1/4 inch by 3/4 rabbit in the solid wood then glued the ply into the rabbit. Since you want this edge band to help support the shelf, this method makes sure the weight on the shelf is transferred directly to your edging strip. No mechanical fasteners needed.
This is probably a little more work than the biscuits or pocket holes, but if you don’t have a biscuit cutter or pocket hole jig it will do the job.
View jusfine's profile
jusfine
2422 posts in 2977 days
#4 posted 06-09-2012 09:20 PM
Lifesaver’s plan is what I would do also, it will provide more glue surface and support.
Those are large shelves, make sure your cleats on the wall are nailed or fastened securely to the studs to prevent them from crashing down.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View JJohnston's profile
JJohnston
1622 posts in 3343 days
#5 posted 06-09-2012 09:24 PM
I think this is what Lifesaver is saying, and I’d go this way. Not only are mechanical fasteners not needed, they wouldn’t do any good anyway – mechanical fasteners don’t transfer shear across a joint, and that’s what you’ve got here. Just make sure they’re glued good, and use something that doesn’t creep, like plastic resin glue instead of yellow.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Loren's profile
10476 posts in 3699 days
#6 posted 06-09-2012 09:27 PM
You can just glue it but make sure you aren’t gluing a distortion
into the shelf when you do.
An argument could be made for actually gluing a center bow into
the plywood to counteract weight on the shelf. Even with
the overbuilding you are doing, I’d be cautious about expecting
the shelf to support books without bowing a bit in the center –
hence the theory about gluing a counter-distortion into it.
If using sold wood for the front you can mill a bit of a rabbet
into the front board (solid wood part) and use the rabbet for
alignment. If you have a biscuit joiner that is easy too. I
wouldn’t bother with dowels. They aren’t worth the
trouble for this job.
View waho6o9's profile
waho6o9
8238 posts in 2628 days
#7 posted 06-09-2012 09:29 PM
+1 for Lifesaver’s plan as well, maybe front and back if you can do it.
If the shelves are 24 inches deep you might want to consider a center support also. Post pictures when and if you have time. Sounds like a fun project.
All The Best.
Lifesaver2000
#8 posted 06-09-2012 10:05 PM
The drawing above by JJohnston is exactly what I was trying to describe. I will also mention that this is a good time to check the Sagulator to make sure that amount of edging is enough. I checked it using the default loads, and it seems to just barely come in under the maximum on sag. Without the edging though it would be much worse.
View Sawkerf's profile
Sawkerf
1730 posts in 3120 days
#9 posted 06-09-2012 10:07 PM
Another agreement with Lifesaver and JJohnston. Just make sure that your solid wood is ever-so-slightly proud of the ply shelf surface. If it’s too low, you might get a sand-thru. If it’s too high, be careful saning it flush to avoid sand thru.
Lifesaver2000
#10 posted 06-09-2012 10:08 PM
Well, just re-read the OP, and he said the shelf will be supported by cleats on three sides, so with this amount of edging on the front sag should not a be a problem.
Lifesaver2000
#11 posted 06-09-2012 10:11 PM
What has worked well for me on making the shelf and edging flush is to use a flush trim bit on the router table with a high fence that has a gap on the bottom for the edging. Since the plywood is 23/32, if you make the rabbet 3/4 “deep” then that gives you 1/32 to trim off with the router bit. Done right it makes for a perfectly smooth transition.
avxflyer
#12 posted 06-10-2012 12:38 AM
Thanks for all the tips! My initial plan was to use dowels. I bought a jig and went to use it this morning and found it sucked! The included bits were bent ever so slightly and I knew the project would suffer from it. By the time I ran into this issue, I already had the cleats installed and they extend the full depth of the shelf, the same as the plywood. If I go with the method above in the pictures, which seems to be the best, I’d have to remove all the cleats and trim off the depth of the cut in the edging so that the edging could extend the whole width of the shelf, or I’d have to make an additional notch out on either end of the support. I’ll chalk up that mistake to education for next time. The other problem for me on this solution is, I don’t have a router table or a steady hand! I’m going with the biscuit idea and add another tool to the toolbox. THANK YOU ALL!
View gfadvm's profile
gfadvm
14940 posts in 2742 days
#13 posted 06-10-2012 02:04 AM
You can cut that rabbit on the tablesaw quickly and easily if you choose to.
