booster pump for a dust collection system
Forum topic by gigjoec posted 06-09-2012 05:57 AM 3308 views 0 times favorited 6 replies Add to Favorites Watch
View gigjoec's profile
gigjoec
5 posts in 4082 days
06-09-2012 05:57 AM
Topic tags/keywords: dust collection
i have a 1500sq ft shop in my garage its in a ” L” shape, i ran 6 inch pvc pipe for the main run and broke it off to 4 in and 2 1/2 inch, the current dust collector is at the rear of the shop. its a twin bag 3 horse general. my problem is that all the items that need the most suction is at the furtherest point away from the dust collector. sliding table saw, 22” planer, 12” jointer because of the size of the machines they have to be in the front. what i need to know is …......
i have another blower/motor setup is it possible to put it up front to work as a in-line booster to provide more suction for the rear collector,
has anyone ever tried something like i’m trying to do ?,
thanks
joe
TopamaxSurvivor
18269 posts in 3673 days
#1 posted 06-09-2012 06:25 AM
No, haven’t tried it, but I’d put it at the back end blowing into the line.
View Scot's profile
Scot
344 posts in 3393 days
#2 posted 06-09-2012 07:36 AM
I have had to do the very same things years ago. The difference was I didn’t have a 3 HP main blower, I had a 1.5 HP main and installed a 1 HP blower on the outlet to my jointer discharge. It worked very well.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
4985 posts in 2490 days
#3 posted 06-09-2012 11:42 AM
I have not tried that, but I’d bet just upsizing the small ductwork would reap huge benefits. Choking the ducting down can really impair airflow. If your tools have small ports, they need to be upsized as well. That said, I have read where others put blowers in tandem and had good results…..but I doubt even that would help with small ducting. Distance can slow the air flow down, but not nearly as much as undersized ductwork.
View killerb's profile
killerb
150 posts in 2395 days
#4 posted 06-09-2012 12:58 PM
What Fred said. Run the 6” as far and as close as you can, then go to the 4” at the machine. bob
-- Bob www.bobkloes.com
gigjoec
#5 posted 06-11-2012 05:22 AM
what would you use to measure the CFM at a machine, i’ve never done it nor do i have a clue on what to use to do it ….....
View Scot's profile
Scot
#6 posted 06-11-2012 05:31 AM
Make friends with an HVAC guy. Then borrow his rotometer to measure the air flow.
