Grizzly G0555LX First Impressions (w/Pictures)
Forum topic by DrewM posted 06-08-2012 01:22 AM 13226 views 0 times favorited 35 replies Add to Favorites Watch
View DrewM's profile
DrewM
176 posts in 2997 days
06-08-2012 01:22 AM
Topic tags/keywords: band saw bandsaw grizzly
I finally had the opportunity to get a bandsaw for my shop and after lots of research I decided on the G0555LX. This saw has some extra features from the other saws in the G0555 series which are cast iron wheels, rack and pinon upper blade guide adjustment, and a T-square style fence. From the reviews I have read the other 14” grizzly saws are hard to beat for the price so I figured this new saw was a safe bet. Plus with the introductory price I couldn’t resist. I also ordered the mobile base recommended by grizzly for this saw.
The mobile base shipped via UPS and arrived a few days ahead of the saw itself which gave me a chance to assemble it. I forgot to take pictures of the base during assembly but it can be seen later in the post fully assembled. The base itself is pretty good, its very sturdy and decently made. I had to run a tap through the threads for both wheel locks and a few of the mounting holes for the casters needed minor file work for the bolts to fit correctly. Overall I find it to be a good base, but I may try another brand for my next.
The saw arrived via freight in two boxes one for the stand and one for the saw. I opted for lift gate service and the delivery man was very helpful in moving the shipment into my garage, hats off to NewPenn freight.
(sorry if the pictures don’t display well, I’ve had some issues correctly resizing them)
The stand and saw were very well packaged except for the area near the back of the motor of the saw. On mine I found the grille for the fan slightly bent and contacting the cooling fan. Not a huge deal and only took some minor bending to correct. All other parts were perfect. The manual for the saw is buried at the bottom of the box containing the saw, I found this slightly annoying since I like to peak and the manual before removing things from packaging.
Assembling the base was pretty simple and only required basic hand tools to accomplish. The stand fits well in the mobile base. The powder coat finish of the base is very nice looking and seems pretty tough. Fully assembled I found it to be extremely sturdy and well built, I think it would easily hold twice the weight of the saw with zero issues. A+ to grizzly on this one.
Assembly of the saw was very straight forward and the directions are clearly written. I recommend having an assistant help you place the saw up on to the stand. Its pretty heavy and awkward to carry. I checked wheel alignment on my saw and out of the box it was within 0.005” of being parallel and coplanar…good enough for me. The cast iron top ships heavily coated with cosmoline but was easy to clean up with some wd-40 and rags. Attaching the top and trunnion assembly and squaring it to the blade is very simple and outlined well in the manual. I found the table to be well machined and perfectly flat. The fence is also easy to install and adjust. It moves very nicely along the table and the tape readings are easy to see through the magnified lens on the fence. The instructions cover all your needs for using and adjusting all parts of the saw. Its nice to read a well written manual for once, thanks grizzly.
Overall my first impressions of this saw are very high, the fit and finish is superb and the design was well thought out. I find the saw easy to use and the rack and pinon upper blade guide makes adjustment very quick and easy to do. The saw runs extremely smooth and quiet and has no vibration at all. Blade removal and installation is slightly difficult due to the length of the front fence rail to the left side of the table. It gets in the way when the doors are open, but once you get the idea it isn’t all that hard to do. Having a quick release for the blade tension is also a nice feature. The 3/8” blade shipped with the saw isn’t that great and leaves a pretty rough finish on just about anything ran through it. I expected this, however I’m going to stick with it since I plan on getting a riser kit as soon as grizzly makes them available to take advantage of resawing boards wider then 6”. Dust collection is ok at best, this saw lacks an under table dust port. Upgrading that area is high on my list of things to do. To prolong tire life I plan to install wheel brushes soon. As of now I’m very happy with the saw, after a few months of use I will post an official review of it in the LJ review section.
-- Drew, Delaware
35 replies so far
View tyskkvinna's profile
tyskkvinna
1310 posts in 2984 days
#1 posted 06-08-2012 01:28 AM
Funny, I got the exact same saw today and my experience is nearly identical to yours! I am pleased. I also am waiting for the riser kit (September!! wtf.) so I did invest in a couple of nice blades because I am going to heavily use them between now & then.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
DrewM
#2 posted 06-08-2012 02:04 AM
Yeah I might just buy one or two blades for now until the kit gets here
-- Drew, Delaware
View Howie's profile
Howie
2656 posts in 2921 days
#3 posted 06-08-2012 02:18 AM
I have the GO555X and have been very happy with it from day 1. I’m sure you will enjoy your LX just as much.
(go on and buy a good blade, it’s worth the investment)
-- Life is good.
View MichaelAgate's profile
MichaelAgate
398 posts in 2321 days
#4 posted 06-08-2012 02:50 AM
Ok, you are LUCKY!
-- Michael and Matthew
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2266 days
#5 posted 06-08-2012 02:55 AM
I have been amazed at grizzlys new products very nice saw.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3229 days
#6 posted 06-08-2012 03:16 AM
Thanks for posting the review. I am on vacation and plan to make the Springfield store one of my stops before heading home!
View DaveFFMedic's profile
DaveFFMedic
81 posts in 2165 days
#7 posted 06-20-2012 01:02 PM
I too anxiously awaited the delivery of my G0555LX. I was disappointed when it arrived with a gaping hole in the bottom of the box. It turns out the factory in Taiwan is shipping and boxing them UPSIDE DOWN! I noticed in your picture of the bottom of the box that all the loose parts are just laying on the cardboard. Also, the circular Styrofoam piece which is supposed to protect the motor fan cover. Your saw was shipped upside down like mine. Consider yourself lucky your saw was not damaged.
In my case, the box was apparently dropped (unbeknownst to me) at some point in transit. This is a separate issue from the torn open box. Because the saw was shipped upside down in the box, the motor and fan cover were woefully unprotected and thus suffered damage. The impact was so forceful that two of the three Philips head screws holding the fan cover to the fan body were SHEARED OFF! The fan blade was damaged and the fan cover was dented.
I am missing several parts which, I assume, fell out after the box was damaged. A bag of hardware for the fence, the tension release lever, and one of the trunnion locking knobs was missing. Three weeks after I contacted Grizzly about these issues, the parts have just shipped from Missouri. (On a side note, don’t order anything from Grizzly when there is a tent sale going on. I was informed that my parts might take longer to ship because everyone is busy at the tent sale. Not so good customer service if you ask me.)
All of this could have been avoided if the box were shipped right side up. The damage to the cardboard box would have been minor. All of the parts would have stayed in the box. And, if right side up, I would be willing to bet the saw would have survived the drop which damaged the motor fan and cover.
The box didn’t look too bad from the outside. Since it weighed 200 pounds, I wasn’t going to flip it over to inspect the damage. I felt with my hand and could feel the table. It still had the protective plastic and I couldn’t feel any damage. I noted the damage to the box on the shipping papers and accepted the delivery as damaged.
When I was able to get someone to help lift the bandsaw out of the package, I noted this damage to the motor. It was the first indication that something was wrong. I immediately went through the box and inventoried all of the pieces to identify everything that was damaged or missing.
Dave
View Bill White's profile
Bill White
4930 posts in 3958 days
#8 posted 06-20-2012 02:55 PM
My 0555LX experience has also been a good one.
One note about the fence. It will rock from side to side ‘cause the wings don’t rest on the rails. I added small plastic stick-on pads to each end of the wings to stop the rocking. I’m looking for nylon tipped gib screws to thread into the holes that are pre-drilled in the wings.
All in all, I very well pleased with the saw. They sure do have enough decals on the covers.
Wonder why the 0555 riser won’t fit the LX?
Bill
-- bill@magraphics.us
DrewM
#9 posted 06-20-2012 10:53 PM
Bill, I believe the other 0555 risers do not fit because of the rack and pinon upper blade guide assembly on the lx.
-- Drew, Delaware
View steamfab's profile
steamfab
76 posts in 2179 days
#10 posted 06-28-2012 02:04 PM
Another satisfactory review of Grizzly band saw. Nice-looking saw you got.
Bill White
#11 posted 06-28-2012 02:29 PM
Drew, I hadn’t thought about the rack side of the riser. Duh!
Thanks.
Bill
View crashn's profile
crashn
528 posts in 2463 days
#12 posted 06-28-2012 02:35 PM
Bill W,
Not sure if this will help, but my grizzly table saw had nylon tipped gib screws for the fence. Mine is a G0715p, but other grizzly table saws may use the same type of gib screws.
-- Crashn - the only thing I make more of than sawdust is mistakes
View Heisbert's profile
Heisbert
34 posts in 2177 days
#13 posted 06-28-2012 08:05 PM
As what I always expect with Grizzly saws, they’re really good.
View Oakdesk's profile
Oakdesk
11 posts in 2145 days
#14 posted 07-09-2012 10:04 PM
After reading DaveFFMedic’s post about his experience, I can report a similar tale. Back in mid-June, I received my G0555LX upside down with a huge hole in the bottom of the box. It did not occur to me that the factory would ship the saw upside down. The table and fence were intact in the box, so I noted the damage on the bill of lading and signed off. Only later did I discover that the rear fence rail, hardware bag, and tension release lever were missing. The miter gauge was also damaged. The next day, I called Grizzly to report the missing items. To their credit, they began to work on the matter right away, as shown by several phone calls from customer service. To their discredit, it took them three weeks to get the missing items to me (I guess I got caught up in the tent sale that Dave mentioned.) I was able to use the saw without most of the items; I used a screwdriver as a tension release lever until I got the real one.
I’m really pleased with the saw so far; it’s a big change from the 10” benchtop that I used to own. I did get a bad Olson 1/2” blade that gave me some vibration, but when I swapped it out for an Olson 1/4” everything smoothed out again. I think I got good value for the money spent.
View jaysonic's profile
jaysonic
219 posts in 2140 days
#15 posted 08-29-2012 03:18 AM
Just clicked “buy.” I live in Canada though, somewhat nervous about the shipping, but I’ll make sure to check it out really well.
showing 1 through 15 of 35 replies
