Anyone know if Cove and Roundover router cutters are available larger than 1"?
Forum topic by 404 - Not Found posted 06-07-2012 04:51 PM 1743 views 0 times favorited 8 replies Add to Favorites Watch
404 - Not Found
2544 posts in 2839 days
06-07-2012 04:51 PM
I already have cove and roundover bits in 1” radius. Is this the limit for router cutter sizes or does anyone know of a supplier of larger bits?
I could go for spindle tooling if I have to, I would prefer using the router if possible.
TIA
8 replies so far
116804 posts in 3447 days
#1 posted 06-07-2012 05:05 PM
I think MLCS has larger ones also.
View DS's profile
DS
2855 posts in 2290 days
#2 posted 06-07-2012 05:19 PM
Above 1” router bits can become problematic. The velocity at the outermost part of the bit gets very high even at slower rpms.
Most often, the tool of choice for such large profiles becomes a shaper with a rather large head.
Router bits are out there, but, they should be used carefully.
9756 posts in 3517 days
#3 posted 06-07-2012 05:45 PM
Magnate has them up to 1.5” radius. Such roundovers are
used for bullnosing the hardwood edges of laminate audio
and video mixing consoles.
http://www.magnate.net/index.cfm?event=showProductGroup&theID=40Magnate.net
View Mainiac Matt 's profile
Mainiac Matt
7552 posts in 2198 days
#4 posted 06-07-2012 05:46 PM
Grizzly also has the 1.5” round over
-- Pine is fine, but Oak's no joke!
View GrandpaLen's profile
GrandpaLen
1648 posts in 2142 days
#5 posted 06-07-2012 08:14 PM
TIA,
I have a 1.5” radius, 0.5” shank, Frued Bit that I use on Red Oak. Only use a bit of this size with a table mounted, 2.5 hp or larger, router.
You will need to run it at between 16,000 – 18,000 rpms. and you should trim the corners/edges off your stock at a 45 degree angle, to avoid having to remove so much waste with the router bit and then remove about a 1/16” of wood at a time in each pass.
Easy does it and you should be just fine. – Len
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View MonteCristo's profile
MonteCristo
2099 posts in 2058 days
#6 posted 06-08-2012 03:36 AM
Check CMT They are high quality Italian bits and come in big sizes.
404 - Not Found
#7 posted 06-16-2012 09:58 AM
Thanks for the info. That gives me something to work on.
13594 posts in 3211 days
#8 posted 06-16-2012 11:15 AM
this was made with 1 1/4” diam. bits
build blog
http://lumberjocks.com/patron/blog/20399
i see there are maybe bigger bits now at
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_core.html
and
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_bull.html
these bits match each other
and i am not really sure why the stock was 1” x 1 1/2”
it took to make it
my brain is turning to mush at times
so i just accepted it after trials with different stock sizes
as i say there appear to be larger here now
but at that time (couple of years ago)
that is what i could find
