Dust collector finally hooked up
Forum topic by robdem posted 378 days ago 662 views 0 times favorited 6 replies Add to Favorites Watch
View robdem's profile
robdem
177 posts in 804 days
378 days ago
Bought the harbour freight dust collector last year finally have gotten around to running all the pipe for it .Pipe is thin wall drainage pipe from home depot 4 inch pipe . Used 45 degree elbows to make all of the turns . All the machine have there own blast gates have a mix of metal and plastic gates .Collector works fine only use one machine at a time so suction is not a problem and I clean the dust bag everytime I empty the saw dust.
View DIYaholic's profile (online now)
DIYaholic
7581 posts in 873 days
#1 posted 378 days ago
Congrats. Looks good.
Have you looked into the Wynn canister filter? It improves performance & reduces the amount of fines getting into the air (great for maintaining lung function).
-- Randy-- I may not be good...but I am slow!
View Kelby's profile
Kelby
117 posts in 608 days
#2 posted 377 days ago
Nicely done! You’ve clearly put in a lot of work. Dust collection makes it much more enjoyable to work in the shop.
One suggestion is that on your bandsaw, you are restricting airflow the way you go from the 4” PVC to the two ports on the bandsaw. The restrictions are (a) using a T-fitting rather than a wye, and (b) you reduce from 4” to 3” (or perhaps its 2-1/2”, it’s hard to tell from the picture) well in advance of the T. These would be simple and inexpensive to correct. First, replace your T with a wye that has 4” on one side and two 3” openings on the other (or 2-1/2” or whatever it is). Or use a 4” wye and a couple of 4” – 3” reducers on the bandsaw side. Second, use 4” flex hose to connect the 4” PVC to the 4” opening on the wye.
The bandsaw produces a lot of the very fine (almost invisible) dust that is the most dangerous to your health, and the fine dust requires the most airflow to capture. Anything you can do to eliminate these restrictions will make for a big improvement at the bandsaw.
-- Kelby
View jeffreywazz's profile
jeffreywazz
1 post in 377 days
#3 posted 377 days ago
I am having the similar kin of requirement in my shop, I was looking for something like this. After reading the reviews this products would be the best option as per my requirements.
Sweating Treatment
View ducky911's profile
ducky911
166 posts in 987 days
#4 posted 377 days ago
I am worried too about that filter. It is my understanding that it is the dust you can not see that is bad.
Nice work on the pipe.
robdem
#5 posted 377 days ago
Diyaholic have looked at the wynn filter want to get it but don’t have the money for it yet .
Kelby I know about the y i need hooked it up to see how it would work and that was what I had on hand have to get y and some more 4 inch hose
View ronniebo's profile
ronniebo
51 posts in 863 days
#6 posted 377 days ago
Now check out the Thien add-on separator.
You will love yourself once you go to the trouble of making even the simplest version.
I have and it couldn`t be better for the top filter stays almost clean.
Ron in Hobart
