Armoire hinges- 270 degree ??
Forum topic by daveintexas posted 95 days ago 243 views 0 times favorited 4 replies Add to Favorites
View daveintexas's profile
daveintexas
203 posts in 357 days
95 days ago
Topic tags/keywords: hinges armoire 35mm
I am building an armoire similar to this. The upper doors will each have two sets of hinges. I figured on using piano hinges for the inside hinge. But on the outside hinge do I need 270 degree hinges?
And rather then those “no mortise” hinges in the pics, is there a concelled 35mm hinge I can use??
Thanks
Armoire
-- MISSION FURNITURE-My mission is to build furniture
View Loren's profile
168 posts in 129 days
95 days ago
European 35mm cup hinges are smooth operators but
they stick out like a sore thumb.
You might want to look at barrel hinges like SOSS hinges.
They install into holes or mortises routed into the edge of
the door. You want 360 degree opening hinges I think.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online business building
2745 posts in 460 days
95 days ago
Dave;
I’m sorry I didn’t get back to your P.M. on this.
As Loren says Soss hinges are a great solution to this.
I posted a few pictures on a project I used them on. The hinges are a bit larger than you need, but it does show how they work and how open and closed the doors can be.
They should be perfect for your application.
I’m looking through the Blum hinge catalog as we speak.
My concern with this is I generally have to buy these in boxes of fifty hinges and fifty base plates.
It may be possible to cross reference them to another brand.
If I do find something, I’ll get back to you.
View Don Newton's profile
Don Newton
93 posts in 99 days
95 days ago
Dave,
As previously stated the 35mm 270 degree hinge is the size of a lunchbox! The Soss hinge will be a good choice. Be careful that you use the largest hinge you can (they are selected by the thickness of the material). Use at least 3 per door to help keep the door straight and DO A MOCK-UP for the machining. Most of the Soss hinges have no adjustment and the placement of the hinge from the face is critical for it’s operation. Instead of the piano hinge why not use Soss everywhere since you will already be set up for it?
Good luck and remember plan twice, avoid frustration. I just made that up!
-- Don, Pittsburgh
daveintexas
89 days ago
Thanks to all for the help. I looked at the SOSS web site, but they indicate their hinges only open to 180 degrees. I dont think that will work with the double doors and allow them to swing back to the sides.
Thanks
Dave
Bookmark And Share This Page
