use of cross dowels
Forum topic by Danpaddles posted 06-06-2012 10:21 PM 4740 views 0 times favorited 8 replies Add to Favorites Watch
View Danpaddles's profile
Danpaddles
573 posts in 2306 days
06-06-2012 10:21 PM
I am helping an older lady rebuild (assemble?) a light table. It is a nice finished oak frame, originally held together with cross dowels and long screws. Think of the drafting table you used in high school (if you are as old as I am-).
Ref. this Rockler product-
http://www.rockler.com/product.cfm?page=367&site=ROCKLER
But- the holes on her unit require about a one inch dia. dowel. Or should I say- they are about an inch dia. The cross holes are about 3/8 inch dia.
Do you think a smaller dowel could still have enough holding power, sitting over to the edge of the hole? Or should I keep looking for a larger cross dowel? Not sure where else I can look- I have just about exhausted the ‘net.
thoughts? Should I march ahead with the smaller dowels? I could maybe shim out the hole with fender washers.
thx-
-- Dan V. in Indy
8 replies so far
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#1 posted 06-06-2012 10:25 PM
Maybe use all thread and double nut it, if I understand your situation correctly.
View bondogaposis's profile
bondogaposis
4719 posts in 2345 days
#2 posted 06-07-2012 12:02 AM
Look for bed bolts. Here.
-- Bondo Gaposis
Danpaddles
#3 posted 06-07-2012 12:42 AM
Bondo- right idea. Wrong size. That is just a little too large. If I were starting from scratch, I might use something like that.
these guys are 3/8 dia.-
http://www.rockler.com/product.cfm?page=367&site=ROCKLER&utm_source=gan&utm_medium=aff&utm_campaign=feed&CFID=85075915&CFTOKEN=8641bf7055519084-F6BC264A-1372-6771-F6DED52A1273279A
but they will sit in a hole with 15/16 dia.
Now that I think on it- I might just buy a package of the little ones and try them. Only out 5 bucks if they don’t work, and hey, it is always fun to go to Rockler, any excuse works.
-- Dan V. in Indy
View levan's profile
levan
472 posts in 2973 days
#4 posted 06-07-2012 01:11 AM
I don’t know the cost or shipping, but it appears that these may work for you. Page H-5_
Another option might be, to just use a square nut. My old work bench top is put together this way.
wherever strong
right angle joints are required. Fastener
applies even, controlled pressure,
creating a strong joint that can be
quickly assembled or disassembled.
Installation requires drilling one hole
for bolt and one hole for cross dowel.
Dowel is electro-plated steel. 1” Ø x 1-
1/4” L with 3/8” – 16 cross thread.
Cross dowel only 1” O.D. x 7/16” I.D. http://www.organsupply.com/catalog_ordering/view_our_catalog/pdf/Section%207%20-%20Misc.%20Tracker%20Parts.pdf
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View stefang's profile
stefang
15881 posts in 3328 days
#5 posted 06-07-2012 08:02 AM
Hi Dan. Another solution would be a hardwood cross dowel sized to fit the hole and threaded to accept the bolt. I have used wooden cross dowels in my homemade outdoor furniture with wood screws and they have held up perfectly over many years. I do use 8mm unglued dowels on either side of the screw to keep the joint aligned and add strength. The wood screw can be countersunk and plugged for looks.
View MrRon's profile (online now)
MrRon
4761 posts in 3237 days
#6 posted 06-07-2012 04:52 PM
What you can do is take a piece of dowel that fits the hole; drill a 10mm (13/32”) hole through the end of the dowel for the xdowel; crossdrill a 5/16” hole through the dowel for a 1/4” machine screw
View Mainiac Matt 's profile
Mainiac Matt
8029 posts in 2322 days
#7 posted 06-07-2012 05:14 PM
oops
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
Danpaddles
#8 posted 06-08-2012 01:07 AM
The square nut looks like the best bet. And the cheapest.
Thanks all who replied.
-- Dan V. in Indy
