Anti-kickback splitter for Delta left-tilt contractor's saw
Forum topic by jstewart posted 150 days ago 230 views 0 times favorited 2 replies Add to Favorites
View jstewart's profile
jstewart
139 posts in 628 days
150 days ago
Topic tags/keywords: splitter safety delta table saw accessories
I’m getting tired of installing and removing my table saw’s splitter/blade guard assembly every time I need to change from a through cut to a dado or groove cut. I have been doing rip work without the guard installed the last few times I used the saw, but I’m always concerned about kickback. I’m looking for a good splitter that is easy to install/remove when needed. I’ve seen the nice Biesemeyer splitters for Delta Unisaws. I haven’t seen one that claims to work for the left-tilt contractor’s saw. Does anybody know of anything like that for my saw?
-- Joshua, Olathe, Kansas
View hcbph's profile
hcbph
12 posts in 155 days
149 days ago
Check out: http://www.walnutacrewoodworking.com/
I’m using on of his double-ended push-pull splitters and it works very well for me.
Paul
View jvbanjo5's profile
jvbanjo5
3 posts in 147 days
147 days ago
Check out the Grip-tite splitter available from Mesa Vista Design. It is a low-tech, yet very effective splitter that is designed to be easily removeable, especially when used with a zero clearance throat plate. You can see it at www.mesavistadesign.com or www.grip-tite.com. It only costs around $10.00
Bookmark And Share This Page
