| Forum topic by Bill White | posted 379 days ago | 2542 views | 0 times favorited | 19 replies | ![]() |
379 days ago |
I keep seeing varied opinions on the merits, or lack thereof, for the urethane or rubber tires for bandsaws. -- bill@magraphics.us |
19 replies so far
#1 posted 379 days ago |
My experience with urethane was that they could be worth it, depending on your saw. When I put on the urethane tires, they were thinner than the OEM rubber ones and my saw no longer had the vertical travel necessary to properly tension the blade. Having already purchased and installed them, I shimmed up the upper arm of the saw about a half inch so that I could get the right tension. If I could go back and do it all over again, I would likely go rubber. -- Brian T. - Exact science is not an exact science |
#2 posted 378 days ago |
All I have used is rubber. They are easy to crown. That’s why I use them. -- Bob www.bobkloes.com |
#3 posted 376 days ago |
When you compare rubber tires to urethane ones, I would say urethane tires stand out. Urethane tires are made of flexible urethane instead of the usual rubber; they stay flexible longer to increase the performance of your blade and; since you don’t need to glue them to the wheel, installing and replacing is much easier, too. Urethane tires may cost more than rubber tires but it’s worth the price. But don’t worry, some websites offer great discount on tires and some band saw parts (like this website) – www.bandsawparts.com |
#4 posted 376 days ago |
I agree with Heisbert. Been using the tires for a little over a year. They were a bit painful to install, and it would have been easier with another hand, but the benefit was worth the effort. I do some re-sawing using a 3/4 blade and have chewed through a few rubber tires, the urethane tires a holding well with no noticeable ware. -- Nicky |
#5 posted 376 days ago |
I have two bandsaws, one with urethane, one with rubber. They are both 3/4HP, 6” cut height, one is a Reliant, one is a Porter Cable, so neither is a high quality brand. They are almost identical units, save the Reliant with rubber is 11 years old, been moved three times, and sat for two years in an unheated garage while I was in China. They both have been equipped with bearing guides on top, both have cool blocks on the bottom. Tables are about identical. Both are two speed. The newer unit with the urethane tires, I initially liked it a lot – quieter, seemed to track better, and the blade seemed to “stick” to the track better on the urethane. Urethane on this unit came pre-crowned. This saw also tracks vertical very well. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#6 posted 376 days ago |
Don’t rubber tires have to be glued to the wheels, and urethane tires sit in a groove without glue? The rubber tires on mine gave out within a year. I switched to urethane and they are still good after 5 years. |
#7 posted 376 days ago |
+1 for urethane, purchased on Ebay and I’m content with them. |
#8 posted 376 days ago |
MrRon: Rubber does not have to be glued to the wheels if it is a snug fit. I used to make my own bandsaw tyres out of high density rubber matting and rubber cement. I never glued any of them. |
#9 posted 373 days ago |
Opinions about rubber vs. urethane is akin to opinions about Chevy vs. Ford! I’m running urethane on my Delta and have not had a single problem with them. They replaced some rubber tires that were dried up and cracking. However, I purchased the machine with those rubber tires already on it, so I have no idea how old or how much abuse they were subjected to. Cheers, -- Brad in FL - To be old and wise, you must first be young and stupid |
#10 posted 371 days ago |
Some may like to use urethane over rubber or the other way around, but I would prefer to use urethane tires on my machine’s wheel. For now though, I am using rubber tires because these are original ones installed when I bought this. I am planning to buy new urethane tires at www.bandsawparts.com (the least expensive dealer of after market band saw parts I have found as for now). I am just new to using a band saw so I’m not quite as familiar with all of the machine yet. I think a manual would be useful too! Who knows where to find different band saw manuals? -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
#11 posted 371 days ago |
One thing to make not of is many saws are designed in a way that make urethane tires a non-starter. If you have an older saw or an European saw with flat wheels you will need to use rubber or EPDM tires designed for the saw. The place you have a choice is the modern Asian machines along with most of the Delta 14” cast saws and their clones which have crowned wheels that require a thin tire to conform to the crown, these tires do not need to be crowned themselves. For bandsaws where you have a choice the benefit of urethane is longer life and the lower chance of them developing a flat spot. On these bandsaws I generally use urethane since they are easy to source and are usually cheaper than OEM rubber. Regarding gluing some rubber tires are not designed to be glued like T-track or safety tires used for example on the older 20” Delta and Rockwell saw and some Italian saws like Mini-Max and others. On smaller slower bandsaws you can often avoid gluing rubber tires but it is good form, larger saws with high SFPM rates one has no choice but to glue, try not gluing a 7,000+ spfm bandsaws tires and see how long they stay on… |
#12 posted 371 days ago |
Both rubber and urethane bandsaw tires will do the job. I have 2 bandsaws and have rubber on one and urethane on the other. Urethane will definitely hold up under more usage than the rubber and urethane does not seem to develop “memory” (depressions, grooves, or flat spots) unlike rubber. Thus, the bandsaw I use the most has urethane tires and rubber on the one I use infrequently. Further, I (almost) always release the tension on both types of tires. -- Make more wood shavings and less dust! Steve, Cary, NC |
#13 posted 371 days ago |
GENERALLY speaking, it is recommended that urethane tires not be glued .. rubber tires should be. The rubber tires, on most 14” Delta clone units can sometimes buckle & bulge wherever they are unsupported by the bands due partly to their increased mass. Centrifugal force causes them to fly open, and sometimes they don’t fall back exactly where they should, so you can throw a band .. open up the saw .. inspect, finding nothing wrong .. over .. and over .. and over .. so I’ve been told. -- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ... |
#14 posted 370 days ago |
The use of urethane tires over rubber tires is highly recommended. That is because a urethane tire is an improved version of the usual rubber tire that we have. So, urethane tires are expected to yield better results and performance. We, machine users, should be thankful to those who are behind these successful innovation. |
#15 posted 370 days ago |
Everybody’s into this thread about urethane vs. rubber tires lately. Surfside, you may visit www.bandsawmanuals.com. They have manuals for different types/models of band saw machines. |
| Forum | Topics |
Woodworking Skill Share
8849 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
