Father's day gifts on the way..
« back to Hand Tools forum
Forum topic by bandit571 posted 06-04-2012 04:31 PM 1001 views 0 times favorited 3 replies Add to Favorites Watch
View bandit571's profile
bandit571
21999 posts in 2921 days
06-04-2012 04:31 PM
Topic tags/keywords: question plane
Ok, One such is a Fulton 14” jack plane. Apparently made by sargent. Going in for Re-Hab…
Number 2: a Miller’s Falls #9 type 4-5. Still has the “three-point” lever cap, ugly red handles, black frog. Going in for a Re-hab.
Number 3: A sears Craftsman #3 sized plane. Has phillips headed bolts in the handles. Red frog, large steel adjusting nut. Going to Re-Hab…
And Number 4: A Stanley Handyman H1203. Normal Handyman stuff. Already have a H 1204 in use.
Question; What is with grooving the SIDES of a plane’s body? That Sears plane has them. Do I keep them, grind them smooth, or what All four planes will need their soles worked on, butthat is just part of being in a Re-Hab. But them grooved sides??
Planes will get here in about a week, or so. Will know more then. Hey, I C A N S T O P I F I W A N T T O….
3 replies so far
View Dan's profile
Dan
3630 posts in 3118 days
#1 posted 06-04-2012 05:16 PM
Bandit, I have seen one of those Craftsman planes with grooved sides before and I also wondered why it was made that way. The logical guess is they did it that way for the same reason the soles were grooved. I imagine it would be a lot of work to grind/sand the sides smooth and not only that you would also be removing a lot of material which would reduce the weight and mass of the plane. I would just leave the grooves there if it was mine.
-- Dan - "Collector of Hand Planes"
bandit571
#2 posted 06-04-2012 05:54 PM
Ok, I’ll just clean them up. Phillips headed bolts for the knob and handle, almost like a M-F clone, like a type 5??. It does have a red frog though. Almost a cross between a Stanley, and a Millers falls?
The Fulton Jack will need a tote repair/replace. Also a GOOD clean up, BEFORE I even allow it in my shop. Usual sole work, and maybe a paint job. Put a nice big, ol Camber on that iron….
Them Handyman totes…...eh…...not my style. Base is small, to small to use a #3-#$ style tote template on. Still have a little bit of walnut in the shop…...
Looked up the Millers falls #9. Type 4 early 50s model. Might strip that UGLY RED stuff off, just to see what that wood does look like. And, it ain’t cocobolo….
View Dan's profile
Dan
#3 posted 06-04-2012 08:05 PM
I have a couple Craftsman planes and they both had red painted frogs. I believe they were red because thats one of the colors Craftsman uses in their logo. I think they were made by Stanley but its hard to tell. All of the plane makers pretty much used the same Bailey frog design.
I also have a Millers Falls #9 but I never refinished the tote or knob. The old finish was put on very thick and I just didn’t feel like sanding all that off. I am not sure what kind of wood is under it so when you get yours sanded down you will have to let me know.
