food safe finish
Forum topic by wooleywoodsmith posted 353 days ago 1016 views 0 times favorited 11 replies Add to Favorites Watch
View wooleywoodsmith's profile
wooleywoodsmith
152 posts in 1531 days
353 days ago
Topic tags/keywords: bowl foodsafe help question
How and when to give my bowls a food safe finish?
so Im sure if I were to go back and read through all the forum questions and answers I will find the answer to my question…..any suggestions to a high gloss finish with out using laquer, varnish or shallac?
currently my finishes on my bowls I have only used minwax paste wax which I know is a patrolium (sp?) based and I just don’t feel comfortable putting lettuce and tomatoes with it.
For the bowl that I am currently working on I want to tell the giftee that they can use it as a salad bowl. so my
thoughts are to hit it first with tung oil (I want it to darken a bit) and then finish with multiple coats of bees wax buffing between coats. any thoughts??? right now June 4th at 8am I am right in the middle of my 180 grit sand and moving slow. At what point do you apply oils? after complete sanding? (Ive been going to 800grit lately because I have the paper)
Thank you ,Wooley
-- wooley
11 replies so far
View premieretreeservices's profile
17 posts in 469 days
#1 posted 353 days ago
That sounds good. Tung oil and beeswax are both food safe, and, as far as food safe finishes go, are some of your best options. I would apply a number of coats of tung oil because it is somewhat difficult to apply and needs the extra coats to work correctly. Also, a quick tip, mixing oil with your beeswax, which normally comes off somewhat easily when washed, will make it more water resistant. Good luck!
-- Premiere Tree Services Network: http://www.premieretreeservices.com/
View rdjack21's profile
rdjack21
254 posts in 1098 days
#2 posted 353 days ago
While looking for an answer what is food safe I found this article which you may find interesting:
http://www.woodturnerruss.com/FSOriginal3a.html
-- --- Richard Jackson
87253 posts in 1747 days
#3 posted 353 days ago
Many finishes are food safe the only thing in most finishes that could be a problem are the solvents,but once dry they are safe . Wax does not offer much protection but it is better than no finish at all . If you want a dedicated salad bowl finish General finishes sells a salad bowl finish .
View RogerM's profile
RogerM
316 posts in 569 days
#4 posted 353 days ago
I have had good luck with General Salad Bowl finish
-- Roger M, Aiken, SC
View killerb's profile
killerb
147 posts in 568 days
#5 posted 353 days ago
What Jim said above is correct. bob
-- Bob www.bobkloes.com
View bondogaposis's profile
bondogaposis
1253 posts in 521 days
#6 posted 353 days ago
What Jim said.
-- Bondo Gaposis
wooleywoodsmith
#7 posted 353 days ago
thanks Jim and everyone else. I guess I know what I am gonna be doing now. again thanks, wooley(michael)
-- wooley
View RussellAP's profile
RussellAP
2394 posts in 457 days
#8 posted 353 days ago
Walnut oil is food safe too.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View SASmith               's profile (online now)
SASmith
1368 posts in 1157 days
#9 posted 352 days ago
I used general’s salad bowl finish from woodworker's supply for these bowls.
It is pricey but worth it to me. It penetrates the wood very well too. For the bowl in pic 5 of the above link I just kept giving it coat after coat on the inside without letting it dry and within about 10 minutes it had penetrated all the way through to the outside of the bowl.
-- Scott Smith, Southern Illinois
View Doss's profile
Doss
777 posts in 435 days
#10 posted 352 days ago
Poly is food safe, but you don’t want to use it on anything that’s going to be scraped or cut on. I’d just use it for outside protection actually on things that need to be served on.
So, I’d use the salad bowl finish suggested by SASmith or maybe a butcher block oil depending on how you plan on using the bowls and/or other items.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View MNgary's profile
MNgary
215 posts in 587 days
#11 posted 352 days ago
I use food grade mineral oil on cutting board & condiment bowls. However, while producing a beautiful protective finish that enhances the wood’s grain pattern, it doesn’t produce the high gloss you are looking for, Wooleywoodsmith. Also, it needs to be periodically re-applied by the end-user.
As to when to apply, I only do so after I’m finished sanding.
-- "I dream of a world where a chicken can cross the road and no one questions its motive"' - Anne Nonny Mouse
